Old 02-18-2016, 12:44 AM   #1
karl
karl's Avatar
Driveshaft length?
Does anyone know the length of a driveshaft for a mid 70s shortbed C10 with th350 9inch tail and 12 bolt diff, 2 wheel drive? Thanks
karl is offline   Reply With Quote
Old 02-18-2016, 01:57 AM   #2
J Knight
J Knight's Avatar
Re: Driveshaft length?
FWIW, my 74 c10, TH350 trans, 6 in tail shaft and 12 bolt rear had a 59.5in drive shaft from center u joint to center u joint.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 02-18-2016, 08:46 PM   #3
karl
karl's Avatar
I assume that was a shortbed?
Old 02-18-2016, 09:00 PM   #4
Jake Wade
Jake Wade's Avatar
Around the 56" mark
Jake Wade is offline   Reply With Quote
Old 02-18-2016, 11:26 PM   #5
J Knight
J Knight's Avatar
Yes, I left that part out, it was a swb.
John
Old 02-19-2016, 08:57 PM   #6
65standard
65standard's Avatar
My '85 swb with 350/350 with 9" tail and stock 10-bolt has a 55 1/2" center to center driveshaft..
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-20-2016, 12:08 AM   #7
SkinnyG
SkinnyG's Avatar
My '77 was shortboxed, 350/350, 9" tail and 12-bolt rearend. I had a driveshaft made that was 56-3/8" center to center. Though I think 56-1/2" would have been better.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 02-21-2016, 02:55 AM   #8
karl
karl's Avatar
Thanks again.
Old 02-24-2016, 08:28 PM   #9
Pontiac1976
Pontiac1976's Avatar
Tip: For measuring Drive Shafts
You should measure the Drive shaft from the weld to weld. This way you all ways get the correct measurement, because the end are stander parts, and weld to the shaft.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-27-2016, 12:59 AM   #10
Pontiac1976
Maybe I should have said this for a drive shaft that still installed in the truck or car.
(because If you measurement with the drive shaft on the Truck or Car from center to center yokes will not be the same as off truck or car).
But if you take out your drive out or have it out to measure it. both ways work as long as you double check your both measurement.
and 6inch tall is about 3 inch shorter than his? how does that work? are you using a two part shaft or one part shaft.
Old 02-24-2016, 11:50 PM   #11
SkinnyG
SkinnyG's Avatar
The driveline shop that made mine, specifically asked for center of u-joint to center of u-joint.
I would think wed to weld may not be accurate enough, because you cannot tell where the actual seam is beneath the weld. Not everything is fabricated perfect.
Your driveline shop may vary....
Old 02-25-2016, 08:31 AM   #12
snaptoo
My 80 swb with 350/350 C was 56 3/8 " cl/cl . had it re-tubed to 59 1/2 " for a 400 TH .
snaptoo is offline   Reply With Quote
Old 02-25-2016, 12:07 PM   #13
J Knight
J Knight's Avatar
Same for me.
John
Old 02-25-2016, 02:01 PM   #14
GRADYS Performance
GRADYS Performance's Avatar
The correct way for measuring drive shaft length is center of joint to center of joint. Always measure your own combination to be accurate. Others MAY vary depending on the parts they use.
GRADYS Performance is offline   Reply With Quote
Old 02-26-2016, 08:32 AM   #15
snaptoo
I built driveshafts for our local trash hauler . We used cl -cl on the weld because the weld yokes are standard sizes ! We also had records on each truck as to lengths and hardware , it saved a ton of time for our road mechanic![/RIGHT][/RIGHT]
Old 04-11-2019, 02:06 PM   #16
howell57
Has anyone done a 72 C10 long bed with a L83 with 6L80 trans? Would like to hear if you did a one piece driveshaft and from what engine mount hole.
howell57 is offline   Reply With Quote
