02-18-2016, 09:50 PM | #1 |
user # 2756
universal under dash heaters, anybody have one?
PO gutted the heating/cooling on my 83. I can live without the AC but sure could use some heat. I was thinking of a universal heater box like the ones from vintage air or even a summit/jegs knock off. Anybody have one and maybe a few pics? thanks,
Jim
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
02-18-2016, 10:15 PM | #2 |
Re: universal under dash heaters, anybody have one?
Problem with them is they are not designed to draw outside air, which will cause Windows to fog. So if you do decide to go that route you should plan on drawing outside air into the unit. If I were you , hit a pick and pull, there are millions of these truck grab a complete assembly.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
02-19-2016, 09:09 PM | #3 |
I think you are better off getting the OEM parts from a pick and pull junkyard.
02-19-2016, 11:37 PM | #4 |
Ditto and ditto. Something like a Vintage Air is likely to cost at least twice as much, AND require ten times the work to install with custom mounts, controls, ducting, ect ect. And that 2x price tag is for a simple, basic unit with limited outputs and options. If you want a more versatile unit, you're looking at 4x the cost.
Or you can pull a unit specifically designed to work with your truck, requiring minimal work to install, and easily the cheapest option.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
02-19-2016, 11:59 PM | #5 |
Keep in mind the firewall openings are different from a/c to heater cabs. I have converted them from a/c to just heater. It's not too difficult if you have the parts. I can post pics if you like on how I changed the firewall on dads truck
-Cody |
02-20-2016, 09:51 AM | #6 |
I have the summit dual outlet heater in my 74 k5 and I don't have the window fogging issue mentioned above but it doesn't quite move enough air for my k5 so it only raises the temp inside the cab not makes it hot enough were you can turn it down in a pickup it might work better but if I run across a complete non A/C cab I'll likely be robbing the heater off of it.
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
03-06-2016, 02:34 AM | #7 | |
user # 2756
Jim
03-06-2016, 10:54 AM | #8 | |
03-06-2016, 07:03 PM | #9 | ||
I agree OEM used parts would be cheaper faster.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
02-20-2016, 11:06 AM | #10 |
They make covers too to go from ac to non ac cab. Like 200 bucks though. ..
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
02-20-2016, 07:58 PM | #11 |
user # 2756
Thanks for the replies guys. I am still up in the air.
02-20-2016, 08:49 PM | #12 |
Go for it. I like the idea of getting rid of the big box in engine compartment and cleaning up the firewall. I looked at options a while ago as I'm considering it for my non AC truck. It has to be well under freezing for me to require heat.
That said, I do think the junkyard would be a good way to go, and in the course of removing from a junkyard truck you would learn about the installation. |
02-20-2016, 11:40 PM | #13 |
I used a couple factory holes for reference
-Cody |
02-20-2016, 11:44 PM | #14 |
I butt welded on the right hand side (in the picture) and flanged it behind the outer skin on top and left. Then plug welded along the bottom
-Cody |
02-20-2016, 11:47 PM | #15 |
I had a donor cab to cut from, pretty well free and only took a few hours Most of the time was a quick mock up before welding
-Cody |
02-20-2016, 11:50 PM | #16 |
Much easier when truck was tore down, it's body worked and painted now and you would never tell it was an a/c truck at one time
-Cody |
03-06-2016, 06:01 AM | #17 |
A kit like this http://www.acdelete.com/pages/73-90_Truck.htm would cover most of it depending what all you have missing.
03-06-2016, 07:18 PM | #18 |
user # 2756
Here's the only shot of firewall I have at work:
03-26-2016, 07:58 PM | #19 |
user # 2756
So I broke down and bought a cab, going to take the under hood heating/AC system components off and put them on the 83. The cab is an 86, parts should work on my 83? the wiring looks identical.
