02-19-2016, 06:37 PM | #1 |
1962 cab swap question
I bought a 1962 chevy truck last week after looking at the frame real good I noticed the po had chopped it up so bad I don't want to use it.my question is will my 62 cab fit on a 64 65 66 frame there are a few of these local to me for cheap.
02-19-2016, 06:57 PM | #2 |
1961 crewcab
Re: 1962 cab swap question
yes, but you will have to drill holes for the front cab mounts, they are in a different spot. the rear mounts line up.
there are a few other minor differences- the grill support has cut outs for the 63 -66 frame, the e/brake will mount different, the box mounts are different. 62 has spilt steering column, etcetera... this is a doable project, but you would want to have both trucks for the duration of the swap, so you can utilize the correct pieces from each one.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
