Old 02-20-2016, 10:08 PM   #1
Ken J Martin
Need Some info from people in the know!
Alright, here is the situation, I am trying to determine what speedometer driven gear I need to make my speedometer more accurate. I did a search and have read and looked at web sites to no end.
I have a 1972 K20, with 4:10 gears, four speed,with 285/75-16 tires. the rear tire diameter is 33 inches. the driven gear has 20 teeth. Presently the speedometer is 7 to 8 miles per hour below what my GPS provides. I am assuming I need a driven gear with less than 20 teeth.
Can anyone provide me with the information. What is there presently is a steel gear and not a nylon like found in the various catalogs.
Obliged!
Ken J Martin is offline   Reply With Quote
Old 02-20-2016, 10:39 PM   #2
toolboxchev
Re: Need Some info from people in the know!
Lube the cable it will become a tad bit more accurate. Is that an auto truck? Post some pics. Mine was acting up, I also took the little gearbox apart and cleaned then lubed.
Its fairly accurate now, I figure 1/10 of a mile off every 5 to 10 miles.
toolboxchev is offline   Reply With Quote
Old 02-21-2016, 12:27 AM   #3
swamp rat
swamp rat's Avatar
I run 33's on my K20 and my speedometer is off a little too but i live with it. Do you have a ratio adapter on the NP205 like the 54RA2 in the first link?
A couple links that may help you out.
http://www.transmissioncenter.net/sp...____va.htm#350
http://www.tciauto.com/tc/speedometer-gear-calculator/
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
