Old 02-21-2016, 07:07 PM   #1
Project86
fuel cell access through bed
For those of you with fuel cells mounted UNDER the bed between the frame rails , what are you using for access to fill er up!!
I don't want to just cut a rectangular hole in the bed and attach some hinges and it look messed up
Is there a plate I can purchase to weld into the bed floor?
Something preferably locking to prevent fools from messing with my tank
Project86 is offline   Reply With Quote
Old 02-21-2016, 11:00 PM   #2
JacobSchni
JacobSchni's Avatar
Re: fuel cell access through bed
following
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz
680hp/720ftlbs of NA fun
JacobSchni is offline   Reply With Quote
Old 02-22-2016, 08:20 AM   #3
andrewmp6
can use something like this http://www.jerrybickel.com/fuel-syst...ace-mount.html or http://www.speedwaymotors.com/Chrome...Fill,5854.html
Old 02-22-2016, 09:13 AM   #4
mikentosh
mikentosh's Avatar
We used an access door designed for a newer F350 that I found on Summit Racing. I believe they make a locking version too.
mikentosh is offline   Reply With Quote
Old 02-22-2016, 02:06 PM   #5
bigblock73
yeller
bigblock73's Avatar
Here is how I did mine
http://73-87.com/7387garage/chassis_...ellinstall.htm
bigblock73 is offline   Reply With Quote
Old 02-23-2016, 11:56 AM   #6
kdh454
That door looks good. I may be stealing that idea if I decide to ditch the hinged tail light on my '01.
kdh454 is offline   Reply With Quote
Old 02-24-2016, 12:54 AM   #7
Project86
I like this a lot....how did you fix it up? Any pics of the install?
Old 02-24-2016, 01:27 AM   #8
mikentosh
mikentosh's Avatar
Unfortunately I don't have any install pics. I know my buddy did quite a bit of work around the area to make it look "factory". The door is counter sunk into the bed floor a little bit. We took out four of the the decorative screws, tapped the holes all the way through and replaced with some longer ones going down through the bed that I found at Lowe's.
Here's a locking version of the door: http://www.summitracing.com/parts/asm-6058kl/overview/
Old 02-24-2016, 12:53 AM   #9
Project86
Jeff I actually used your thread you linked and sent it to some fab shops to get a quote on fabrications is there anyway you can tell me exact dimensions?? I know the ring is 1/2" with 1/4" recess
Old 02-25-2016, 01:17 PM   #10
bigblock73
yeller
bigblock73's Avatar
I no longer have the truck or information on the ring, sorry.
Old 02-24-2016, 01:52 AM   #11
Project86
So it looks like there is a plate that was welded and the door mounted to the plate. Then work around the factory ribs.
Thank you for the link as well. I like the look of that a little better
Old 02-24-2016, 01:13 PM   #12
daddyjeep
daddyjeep's Avatar
The work done to the bed floor is what makes that look so nice. cutting a hole and mounting the door is a no brainer. very nice work.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-24-2016, 07:20 PM   #13
slotard
I'd like to do a blazer or suburban tank on my C20 and then run the filler forward to the door in my utility bed just behind the wheel well. Anyone do this? Or I could put the filler in one of the boxes I guess but that might be awkward.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-24-2016, 11:27 PM   #14
HAULIN' IT
Here's mine...First gen S-10 lid & pocket with the top skinned off & replaced with bed floor. Lorne
HAULIN' IT is offline   Reply With Quote
Old 02-25-2016, 04:07 AM   #15
Project86
That's awesome Haulin!!
Old 02-25-2016, 10:21 AM   #16
JWall
Frequent Flyer
JWall's Avatar
Might look at these as well. They aren't as easy for anyone just walking by to open.
I have one in my 76.
http://www.ridetech.com/store/coolca...l-gas-cap.html
- Justin
1 Owner 1976 SWB
