02-26-2016, 10:06 AM | #1 |
Cleaning the printed circuit?
About ready for the printed circuit on my instrument cluster overhaul, whats the best way to clean up the copper contacts on it?
http://67-72chevytrucks.com/vboard/s...d.php?t=588707 |
02-26-2016, 02:46 PM | #2 |
Re: Cleaning the printed circuit?
Use the eraser on a #2 pencil to clean them
02-26-2016, 06:38 PM | #3 |
Maybe clean up the contact points with some acetone on a Q-tip first, then the eraser. Also, as far as lamps with twist lock bases, it helps increase and maintain contact with the board if you re-spring the tabs. Just bend them gently outward with a little screwdriver.
02-27-2016, 10:29 PM | #4 |
Thanks for the info guys!!
03-08-2016, 10:09 AM | #5 |
Going to work on the printed circuit tonight, after cleaning everything should I use die electric grease on all the contact points for the bulbs and the connector?
03-08-2016, 10:24 AM | #6 |
I don't think I would. Grease will just help attract more dirt and you shouldn't have to much problem with corrosion in the cab.
