Old 02-28-2016, 05:30 PM   #1
mikey531
mikey531's Avatar
Interior after tank removal
I would like some ideas on how to finish off my interior after moving the tank to the rear. Or where to look?
Thank
mikey531 is offline   Reply With Quote
Old 02-28-2016, 06:29 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Interior after tank removal
New carpet kit from ACC and add the extra panel to cover the back wall . the new carpet can be ordered to cover the floor all the way to the back wall of the cab after removing your tank they also make a rear panel .
Auto Custom Carpets
https://www.accmats.com/
Old 02-28-2016, 09:33 PM   #3
57larry
Auto Custom Carpets
that's the way I did it
57larry is offline   Reply With Quote
Old 02-29-2016, 01:37 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Interior after tank removal
May I suggest you look over in the truck audio section. Even if you don't plan on a speaker box there are some great idea's in the section for how to do the backside.
http://67-72chevytrucks.com/vboard/f...ysprune=&f=111
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-28-2016, 07:15 PM   #5
mikey531
mikey531's Avatar
Thanks Do you have any pictures?
