Best place to pick up 12v switched power for choke?
I bought my truck down south and it had a Holley carb with no choke provisions. I've since bought a Quick Fuel carb with an electric choke. I'm not great with electrical and was wondering if there is some conventional wisdom on the best place to grab switched power from?
I know I've been asking a lot of silly questions lately but I'm coming from motorcycles for the past 20 years so a lot of this is completely new to me. |
Re: Best place to pick up 12v switched power for choke?
Not trying to be off the subject, but I always use a manual choke conversion kit. I have never had an electric choke, hot air choke, or divorced choke work properly on a consistent basis. With a manual choke, you always know when the choke is open or closed and by how much. Others will post here that they all always work fine for them. I like simple, certain results. A conversion kit costs $12 and takes about 15 minutes to install.
The fuse box is best. I have seen them hacked into the dist wire or alternator wire but running to the fuse box is the best option.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
I ran mine from the back of the starter, it has the second little post that becomes hot after the truck starts.
I've always used a key switched source from the fuse panel as described by Chaplain.
However I've had quite a few cars come through here where I've noticed they are using the positive coil connection, and jumping a wire to the choke. I'm not saying it's the best way, but it seems to work and would be very simple to do, (short wire and 5 minutes of your time) |
