03-02-2016, 01:14 PM | #1 |
correct stock piston for a 230??
http://m.ebay.com/itm/311383036329
Or http://m.ebay.com/itm/311253977358 Just need 1 for 230 replacement 1 states 1/16 ring instead of 5/16?? |
03-02-2016, 01:19 PM | #2 |
Re: correct stock piston for a 230??
Your engine a 230 or a 250? Both pistons mentioned are for 250's but I'm wanting to be sure. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-02-2016, 03:33 PM | #3 |
It's a 230 but these are the only ones I've seen correct with D on the flat top
Were 230 pistons different and do I have a 250? I'm pretty sure it's a 230 unless it was end of 65 model year that they put in 250s |
03-02-2016, 03:47 PM | #4 |
I've never actually gotten a "fact" label on this, but I believe 230 pistons were flat tops. 250's and 292's used the .300 dish pistons. If you can get me an engine number from the block I may be able to decode it. Unless you have already.
03-02-2016, 04:42 PM | #5 |
Block behind motor mount ..3877178 GM 48... Chevrolet / Buick / Oldsmobile / Pontiac / GMC 230, 250 62 – 78
Head between #1-#2 ..4886F7 Intake..385938 GM 17 |
03-02-2016, 04:50 PM | #6 |
I'm leaning towards a 250. Bores are the same for both engines, but strokes are different. The 250 being longer. The 230 has a taller compression height of 1.795 as to the 250 at 1.655. That's why I'm also sure the 230 has flat tops. I'm thinking yours is a 250. Let me make a call to a fellow inliner and I'll get a for sure answer.
03-02-2016, 05:03 PM | #7 |
You have a 250 and you'll want the piston with the 5/16 rings. The 230 has a flat top with valve reliefs and the 250 has the dish piston. If you were to put 250 pistons in a 230 your compression would drop. The piston with the 1/16 ring must be a newer design or something. My racing pistons in my 292 have that same ring size.
03-02-2016, 07:51 PM | #8 |
crazy! all ive read says 250 wasnt in the 65 pickup
guess ill be looking for one of those then with head off can you measure at TDC from piston to head surface to determine stroke? or to measure anything of value? |
03-02-2016, 09:44 PM | #9 |
You are correct. The 1965 C10 did not have a 250ci. If you need 230 pistons, I have 6 230 pistons that I saved from my 1965 230ci. You are welcome to have them all or however many you want - FREE. Send me a PM. I can post a picture of my 230 pistons if you want me to.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
03-02-2016, 09:49 PM | #10 |
Yeah, measure from the top of the piston to the top of the cylinder and that'll get you pertty close.
250 stroke is 3.530 230 stroke is 3.250 So estimate 3 and a 1/2 or 3 and a 1/4. Anyone could have changed the motor out through the years.
03-03-2016, 02:01 AM | #11 |
Piston in question
Do the ones you have look like this? This style I mean |
03-03-2016, 07:03 AM | #12 |
These came out of my 230ci. You are welcome to have them but they do not look like yours.
03-03-2016, 02:33 AM | #13 |
Since you have the head off. Just measure distance from deck to piston at bottom of the stroke.
230 = 3.250" ... 250 = 3.530"
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
03-03-2016, 02:46 AM | #14 |
Had
03-03-2016, 04:01 PM | #15 |
Going to get piston ring it put it in
Checking what I can, resealing what I can but nothing more at the moment |
