03-04-2016, 06:01 PM | #1 |
454 in a 52 1/2 ton??
Anybody ever put a Chevy Big block in a 52 Chevy truck with stock frame and suspension? I have a spare crate motor and have been considering putting it in my 52 with an automatic trans. but I do not want to mess with cutting the firewall or floorboard in the truck. Can this be done with an aftermarket cross member with side engine mounts and a new transmission cross member? I know all about tight fitting applications as I put a big block in my 56 sedan.. If I did not already have the 454... I would probably just order up a small block and make my life much easier.. Anybody done this swap?
03-04-2016, 06:16 PM | #2 |
Re: 454 in a 52 1/2 ton??
I'm seeing a few guys say if you use a small cap HEI a short pump and electric fans it should work other things to consider are headers and the steering shaft a lot of guys need to move it to the side out of the way to slide it together keep us updated!
"Orange Crush" |
03-04-2016, 06:45 PM | #3 | |
03-05-2016, 12:09 PM | #4 |
your 56 was designed and sold with a sbc, the 52 was not
you will need to relocate the steering box
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-05-2016, 08:57 PM | #5 |
03-05-2016, 09:03 PM | #6 |
55.1 GMC Suburban Hydramatic |
03-06-2016, 01:09 PM | #7 | |
03-07-2016, 07:39 AM | #8 |
I did it, iTS a tight fit
Have a other firewall A other transtunnel Frontend from scotts hotrods But it looks good, see my build thread
My chevy 51...... http://67-72chevytrucks.com/vboard/s...d.php?t=541148 www.knutselracing.nl |
03-07-2016, 11:04 AM | #9 |
My biggest concern would be the interference with the column and steering box. SBC is pretty tight in that regards.
03-07-2016, 11:06 AM | #10 |
Not sure who's truck this is, found it in my picture stash.
03-07-2016, 02:24 PM | #11 |
Thanks for the info and pictures.. It helps a bunch to see it in pictures..
