Does anyone know where I can find this bolt?
It's my seat. The bolt that holds the back to the bottom. I've searched my parts catalogs and hardware stores, kragen don't even have it
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
Re: Does anyone know where I can find this bolt?
Try McMaster-Carr. I just got some left hand threaded nuts through them that I could not find anywhere else. Their website is pretty easy to navigate, you just have to know the specs of the bolt.
McMaster-Carr? Looks like it may be a 100 degree flat head machine screw/bolt:
http://www.mcmaster.com/#machine-screws/=11ft4uv Find the correct size and cut to length, if necessary. |
Its like a Grainger. They sell all kinds of supplies and hardware.
A hardware specialty place might help you. You'll likely have to spend some minimum amount of $$$ if they have it, be prepared to buy some other bolts, etc, if you find one...
Awesome thanks. I'll try that.
Here is the bolt. Good luck. I need one too but haven't been able to find a suitable replacement.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
![]() Join Date: Jul 2015
Try Tom @ DLTruck on this site, he has bins of nuts and bolts.
![]() Join Date: Apr 2000
junk yard?
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
From the looks of the other one, there's a lock washer integrated with it? If you have a Fastenal nearby, it might be worth taking the other one out and taking down to the Fastenal to see if they have what you need.
I will state the disclaimer that the ones around here have disappointed me a time or two on what I thought should be a commonly available bolt. You might also want to consider heading over to the parts board, and find DLTRUCK1973's hardware thread and ask if he has one. I've bought a bunch of bolts and other miscellaneous hardware from Tom.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
not to be a smart-ass, but did you check under your seat? Places like that (garage floor etc) usually have them in stock for me, but I don't realize it until I've gone to great lengths to obtain a replacement!
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
First place I looked lol. When I replaced the carpet I looked under the gas tank and under the sill plate covers too
I haven't done this yet; but it was on my list to put a knob-bolt in that location to make it easier to fold the seatback forward when I need access...
The bolt spec should probably at least a grade 5 though if not grade 8 for crash worthiness Example photo attached - that is just the general idea - the one shown isn't necessarily the right threads or length.. |
#15 |
#16 |
try True Value Hardware
#17 |
I found some at a local AutoMart. I needed a couple and the guy gave me some for free. They did not have the lock washer on them and they ended up having a hex head. They threaded in perfect. The couple I got don't match the others, but hey, the upholstery goes over them anyways.
Posted via Mobile Device |
#18 |
#19 |
I found them a ACE hardware, it has an Allen head instead of Phillips but works great.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel |
#20 |
Knuckle Buster, Instructor
![]() Join Date: May 2010
http://www.mscdirect.com/browse/tn/F...593+4287782570
MSC has all kinds of bolts and fast shipping. I don't remember what size they are but the link should get you close.
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
#21 |
![]() Join Date: Dec 2013
Ace hardware
