Old 03-09-2016, 11:35 PM   #1
dennyscars
dennyscars's Avatar
70 Fleetside Bed Questions
What is the process to replace the bed rear cross sill? Also how difficult is the bed removal to replace the bolts and mounting pads.... thanks
dennyscars is offline   Reply With Quote
Old 03-10-2016, 01:26 AM   #2
El Dorado Jim
Re: 70 Fleetside Bed Questions
grind the welds off, replace sill and reweld it, may be hard to get some of the bolts off, spray with rust penetrant,I will spray all of the bolts, wait a day spray again and maybe one more time before I try and get the nuts off the bolts,I have had good success doing this...
El Dorado Jim is offline   Reply With Quote
Old 03-11-2016, 08:06 PM   #3
dennyscars
dennyscars's Avatar
Thanks for that info, however, It appears that I will have to remove the bed as the the rear sill mounts on top of the frame? Wont drop down..... Oh and the bolts are gonna have to be cut off. The nuts are partially rusted away
Old 03-11-2016, 11:16 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: 70 Fleetside Bed Questions
i used a 4x4 with an eye bolt in the center of the wood across the inside of the bed and a cherry picker, it might take a couple of tries to get it centered in the bed then lift it up and roll the truck out, piece of cake!!!!! i swapped 3 beds one morning that way and still made it to a BBQ by lunch.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-25-2016, 04:25 PM   #5
dennyscars
dennyscars's Avatar
Well, got the bed off. Wasn't too bad removing it by myself. Thanks for all the input and info! I do have a question about what I found on the front bulkhead on the bed . There are some numbers and a couple letters on it, T T 376 25/04 (see pic). Should I leave that or is it nothing? Also, there are numbers on the top of the firewall .....Does anyone know where i could get matching yellow spray paint in a can for some touch up or best to get mixed and spray with gun?
Old 03-25-2016, 06:07 PM   #6
bruceman1968
bruceman1968's Avatar
Denny, this thread will give you some insight on those markings.
http://67-72chevytrucks.com/vboard/s...light=graffiti
The 376 is most likely the job number. No idea on the 25/04 or the T T. That's very interesting to see, especially from a Oshawa truck. What does the firewall say? Can't read it in the pic.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
