Old 09-24-2003, 03:55 PM   #1
Adam12
I hate trannys
Adam12's Avatar
Question To Posi or not to Posi?
I have heard that getting a Posi unit for my truck would be a good thing, but are there any cons? How hard would it be to change it from what I have, whats involved? will I have to get new axels and gearing or just the posi unit? Is it somthing that I can read my book and learn how to do or should I make sure somone is there that really knows what they are doing? Im not sure what I have right now I know its not posi, but am not totaly sure on the gears. I think that they are 3.73 I have a 70 chevy that I think came with a manual 292?
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 09-24-2003, 05:37 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I think you better figure out what you have and what you don't then move to the next step.
67Fleetsidedream is offline   Reply With Quote
Old 09-24-2003, 06:26 PM   #3
Gene
Gene's Avatar
Re: To Posi or not to Posi?
I would leave the changeover to someone who knows what they're doing. If a gear is not set up correctly you can ruin it quick, the ring gear must be spaced correctly from the pinion gear or it will wear out prematurely. Oh and I have a posi and I wouldnt have anything else, but mine came from the factory with one.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 09-24-2003, 08:55 PM   #4
Ackattack
Ackattack's Avatar
I just installed an eaton posi a few weeks ago. You need to figure out what gears you have as it will determine which differential you'll need (series 3 or 4). I used my stock gears. I suppose I was lucky. I checked the backlash before, then installed the posi, and it was the same, and the wear pattern looked the same, so it was pretty easy.
Ackattack is offline   Reply With Quote
Old 09-24-2003, 09:08 PM   #5
jef5150
Inline 69
jef5150's Avatar
http://www.richmondgear.com/01instructions.html
jef5150 is offline   Reply With Quote
