03-14-2016, 07:17 AM | #1 |
Sound proofing Doors
As I get to the end of my build on my 58 Fleetside,I started thinking about how I am going to put sound proofing in the doors,there is not room to get my hands in the holes.I thought about spray in foam,but what a mess,thought about stuffing figerglass insalation in the door,but I dont want to trap water
03-14-2016, 10:24 AM | #2 |
Re: Sound proofing Doors
About the only thing I can think of that should be inside your doors anyway is some rust proofing.
Get the kind that waxy and drippy and literally fogs the inside of the door. You can buy a few different brands; they're all good. The product will be clear and make a mess of your floor as you leave the door open for a few days and let it run out the drain holes onto a piece of scrap cardboard. It'll save your doors but will only give a small to moderate amount of sound proofing. If your doors were all apart, you could sound proofing adhesive sheets but by the sounds of it, you're too late for that.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
03-14-2016, 12:09 PM | #3 |
I used undercoating in the doors.
If you were driving the truck without door seals and with rust holes before the repairs it's going to be a night and day difference even without the extra sound deadener in the door. |
03-14-2016, 12:22 PM | #4 |
Hollister Road Co.
Spray foam will trap moisture as will stick-on foam padding or pretty much anything stick-on, fiberglass for sure will. Undercoating or something similar is the easiest and impervious to water or trapping water. If your covering the inside door panels with a material or vinyl then undercoat the door skin and use something like Dynomat on the inner panel. You just need to change the resonance of the outer skin to a level that we can't hear at. so covering the entire outer skin is not needed.
03-14-2016, 03:31 PM | #5 |
Here's what I did to my doors to give access for that very reason. Cut a hole and used an old set of doors to cut panel out of. Now it is a screw on/off access panel. It will be covered with material when all said and done.
03-14-2016, 04:29 PM | #6 |
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
03-14-2016, 04:40 PM | #7 |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
03-14-2016, 05:10 PM | #8 | |
I said this in another post and just copy/pasta here.
http://67-72chevytrucks.com/vboard/s...66&postcount=6 Quote:
adding fiberglass batting will do almost nothing. seal air leaks especially in the window channels and add some mass to the door.
03-14-2016, 05:16 PM | #9 |
Hollister Road Co.
That door looks like someone barfed in it
03-15-2016, 02:59 PM | #10 |
when I say I am nearing the end of my project,I mean it is going to paint,my doors are in primer with no hardware
03-15-2016, 03:12 PM | #11 |
i cut raammat into 6x6 squares to stick on the outer skin of my doors
sound deadening does not have to have full coverage to work and in our trucks is of marginal value since i have full door panels i also stuck a layer on the face of the door
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
