Old 03-16-2016, 11:58 AM   #1
bean
Fuel percolating....I need help!
Situation is this I just put a 305 in my 72 with as edelbrock 1406. Idles great and runs great until it gets warm then dies.. drove down street and back died in the drive. Could hear the fuel percolating in the carb.... how,can I fix this?
bean is offline   Reply With Quote
Old 03-16-2016, 12:11 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Fuel percolating....I need help!
isolate the carb with a phenolic thermal insulating spacer .What intake are you using ? how is the fuel line run from the pump to the carb ? Any other changes made recently before this started happening ?
http://shop.advanceautoparts.com/p/m...ntent=22901572
Old 03-16-2016, 12:16 PM   #3
bean
I used the edelbrock adapter. Is that nit the same ?
Old 03-16-2016, 01:14 PM   #4
boogieman1
boogieman1's Avatar
No it is not the same. The Phenolic spacer is designed to insulate the carb from the intake to reduce heat. I had the same problem until I used one and now no more problem.
boogieman1 is offline   Reply With Quote
Old 03-16-2016, 12:28 PM   #5
bean
The motor is bone stock except for carb and headers. Just finished putting it in so its just. Started
Old 03-16-2016, 12:37 PM   #6
davepl
davepl's Avatar
Are you sure your timing isn't overly retarded? This can happen on long drives on a hot day with winter gas still in the tank, but shouldn't be something you routinely face on a test drive.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-16-2016, 12:59 PM   #7
bean
Yes timing is good
Old 03-16-2016, 01:04 PM   #8
joecaruso
joecaruso's Avatar
I think these carbs a very prone to heat soak. I run the same carb and after running my truck and then stopping the next start is often hard as the fuel has all boiled out. I plan on putting a phenolic spacer on before I put my truck back on the road this year.
joecaruso is offline   Reply With Quote
Old 03-16-2016, 01:14 PM   #9
bean
Is that spacer same thing as the adapter plate? So I can use both?
Old 03-16-2016, 01:56 PM   #10
bean
Anyone?????
Old 03-16-2016, 02:05 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It's not the same as the adapter. The phenolic spacer will help out. So this engine has the stock spreadbore intake on it?
I know you said your timing is "good"... but what do you have it set at?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-16-2016, 02:06 PM   #12
geezer#99
geezer#99's Avatar
Sure!
Use a 1/2 inch one.
http://www.summitracing.com/int/part...1402/overview/
But You shouldn't be having heat problems this early in the spring.
You said your timing was good.
What's your initial timing?
Old 03-16-2016, 02:19 PM   #13
bean
2 degrees if I remember correctly if wrong what as hould it be?
Old 03-16-2016, 02:25 PM   #14
geezer#99
geezer#99's Avatar
At least 12 initial.
Plug off the vac pot on the distributor when you set it.
Slow down your idle after you set it too.
Old 03-16-2016, 02:33 PM   #15
bean
Gonna dbl check it tomorrow instead of buying that spacer. Thanks for the help
Old 03-16-2016, 02:33 PM   #16
davepl
davepl's Avatar
Doesn't sound like timing is "good" to me. Sounds way retarded like I guessed. Bring it up like Geezer says to 10 or 12 BTDC (so long as it doesn't ping when all the mechanical is in).
You have vacuum advance hooked up, right? You don't have a hope without it, unless this is a full race engine set up for it. He says plug it off but he means (if I may be so bold as to assume) when you're setting the initial timing - you hook it back up after.
Old 03-16-2016, 09:59 PM   #17
46stude
Edelbrock carbs are bad about heat soak. A plastic, phenolic, or wood spacer is a must if you run one, IMHO. Put one on my Thunderbird & had an identical problem to yours. Installed a plastic spacer- problem solved.
But check your timing, just in case.
46stude is offline   Reply With Quote
Old 03-19-2016, 10:39 AM   #18
1quik70
Timing and a plastic spacer should cure it, I had the same carb on my truck prior to the rebuild.
1quik70 is offline   Reply With Quote
Old 03-19-2016, 03:28 PM   #19
67chevy_hotrod
67chevy_hotrod's Avatar
My buddy's Impala had a edelbroke on it and it would do the same thing when we were running it down the track. We used a two pieces of wood (little scraps) and taped the ends together so that the fuel like was stuck between em. Temp fix but it helped get down the track a couple more times lol.
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
