03-17-2016, 05:07 PM | #1 |
Parting - 1972 4WD Blazer
Pulling the suspension in "Mid June". I will pull the drivetrain earlier if a can have most of it sold.
I am posting this thread in advance because once I pull the Blazer in the garage to begin the conversion I do not have much room to store the parts I pull and need them gone. I am going to be replacing the 4WD suspension and drivetrain with 2WD, 5 Lug, LS powered and vintage air. I will be selling all the 4WD suspension, drivetrain, wheels and tires and A/C system. Last edited by Frugalmeyer; 03-17-2016 at 11:47 PM. |
03-17-2016, 05:08 PM | #2 |
Re: Parting - 1972 4WD Blazer
I will be keeping the A/C control and dash vents.
03-17-2016, 06:37 PM | #3 |
Interest in the evaporator mounted in front of the radiator. What shape is it in??? Any broken fins??
03-17-2016, 07:04 PM | #4 |
I need vac canister, inside and outside vac actuators, all brackets for actuators, also flapper in cowl.there is a couple of rods that hook to actuators l need.how much to 89015..thanks
03-25-2016, 12:31 AM | #5 |
03-25-2016, 01:35 AM | #6 |
350.00 for A/C system minus control and dash vents. Buyer pays for shipping.
03-17-2016, 07:21 PM | #7 |
What gear ratio are the axles?
03-17-2016, 09:00 PM | #8 |
Looks like RAZ axle code but not sure. Photos attached.
03-17-2016, 09:25 PM | #9 |
How much
03-17-2016, 10:55 PM | #10 |
Does it have a skid plate and cross member for the transfer case? Also how about the gear reducer for the speedometer cable. Would need them shipped to 84043.
Thanks, Paul |
03-18-2016, 12:05 AM | #11 |
Transfer cross member and skid plate.
03-18-2016, 01:52 AM | #12 |
Interested in the cowl vent flap assembly. Stick or auto? Looking for single bend shifter if stick.
Thanks |
03-18-2016, 05:23 AM | #13 |
Possibly interested in all of the AC components mounted to the inside and outside of the firewall plus the compressor, brackets hoses, and other bric-a-brac that you aren't keeping. I don't need the condenser, controls, diverter box or dashboard stuff.
03-18-2016, 05:40 AM | #14 |
Carpe manana
I'd be interested in the following pending condition pics and cost w shipping to 87107:
Radiator Fan shroud Fuel tank skid plate w attach bolts Linkage from shift lever to tcase and or tcase shifter bolt Hei distributor Engine oil dip stick Metal hose strap affixed to inner RH fender w screws Thanks
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 03-18-2016 at 05:43 AM. Reason: Added |
03-18-2016, 11:58 AM | #15 |
I would be interested in a bed mat if its a clean one or even has it
thanks |
03-18-2016, 08:45 PM | #16 |
Is the 4x4 shifter Chrome if so what condition and price?
03-18-2016, 09:18 PM | #17 |
No Bed mat.
03-19-2016, 03:42 PM | #18 |
Interested in
front leaf spring hanger brackets bump stop brackets upper shock brackets rear spring front brackets radiator core brackets |
03-19-2016, 04:52 PM | #19 |
Please put me in line for the AC vacuum ball tank and bracket. Shipping would be to 40353. Thanks
Michael |
03-20-2016, 05:18 PM | #20 |
Moderator
Please list prices per forum rules ASAP. Thank you!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-20-2016, 09:20 PM | #21 |
I am new to this board and will read the rules and try this again. Sorry for any inconvenience.
03-21-2016, 02:00 AM | #22 |
interested in drive shaft.
03-21-2016, 10:56 AM | #23 |
are you selling the hatch
03-21-2016, 08:26 PM | #24 |
I'm giving up first dibs on the AC equipment to any of you guys who may have an immediate need. If no one needs them then I may be baaaack....
03-21-2016, 08:50 PM | #25 |
Radiator 85.00 plus shipping. No leaks.
Fan Shroud 55.00 plus shipping. One hole drilled in center top. DeadheadNM has first dibs. |
