Old 03-18-2016, 04:06 PM   #1
gochoa
help with shifter rods
Well I managed to get my hands on an A833 with the "hybrid" bell, and shifter, etc, but the shifter rod links that came with it don't fit (yeah i overpaid for it, but it's what i wanted). My question is, has anyone had success cutting and re-welding shifter rods (cut, reweld and maybe put a sleeve or the cut part)? I have a couple lying around I can cut and re-weld and re-bend to make them work, wondering if it has been done or am I asking for trouble, trying to not to pay the outrageous amount being asked for the original ones. Or does anyone know other tranny links that can be used instead of the original. Thanks in advance..
gochoa is offline   Reply With Quote
Old 03-19-2016, 04:39 PM   #2
airdale94
airdale94's Avatar
Re: help with shifter rods
i've done it before on a firebird. I had to make a new one , but i forget what I used for a rod. I diddn't bend it but i did rethread it.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 03-19-2016, 09:39 PM   #3
Gromit
How about something like in the attached photos?
With a length of mild steel rod (of the right diameter) and a Tap & Die set and you can make any combination of rods and rod ends you need..
Gromit is offline   Reply With Quote
