Old 03-21-2016, 09:39 AM   #1
mpierce9
Driver and passenger Window channel issues
Hello - For some reason I can't figure out, my windows will not stay under enough pressure from the channels to stay inside the channels once rolled down. Both channels have new felt. I've adjusted the rear channel forward some to increase the holding pressure on the window to help hold it in place but that seemed to be a temporary fix. Any time these windows are rolled down they fall out of the window channel are rattle around inside the door. This also results in making it difficult to roll the window up.
The channels are original to the truck. Should I invest in new window channels? Could this be a problem with the regulator?
These are manual windows on a 1975 Chevy blazer. All windows are manual and have new felt, all other parts of the window are original.
Any advice is appreciated.
mpierce9 is offline   Reply With Quote
Old 03-22-2016, 12:51 PM   #2
Front Range
Front Range's Avatar
Re: Driver and passenger Window channel issues
You adjusted the rear channel felt or the rear track?
There is a single bolt that holds the rear channel track in place, you should be able to adjust the whole track forward to take out the slack.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 03-22-2016, 01:45 PM   #3
mpierce9
I think I've tried that.
