![]() Join Date: Dec 2009
1967 GMC Suburban Build (Poloma)
Picked this up last week. Engine/trans were unbolted from the frame when I bought her. She's a 67 2wd with barn doors, original ivory white with red interior. So I thought to myself " Lets pull the engine out to freshen it up, since it's already unbolted!" I am glad I did! There's a 6" crack on the block! It was recently rebuilt(.030 over), so I will find a block and put her back together. I need to also pull trans out and ID and make sure fluid looks good. I am not going to do anything to the body yet, as I want to get it running. Poloma has hardly any rust. I have never seen one this clean ( maybe a show Suburban)!
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
Re: 1967 GMC Suburban Build (Poloma)
Here we go!
More
Crack in block
Can't beat the 67 GMC grills!
Pulled trans today(700r4). Pulled the pan, and water was the first to drip out! Should I rebuild or rebuild a 350 that I pulled out of my 72? Which trans is better behind a 350?
![]() Join Date: Aug 2015
hey, this is bonestock 72 over here in sierraville, i've got a 350 4 bolt main casting #3970010 that needs rebuilt. It's standard bore. had a rod knock. you could transfer the parts out of your cracked block to this one. supposedly has a steel crank. let me know if you're interested.
#8 | |
