TH400 Leak
Hey Guys,
I have a TH400. I have a transmission leak that looks to be coming from the Speedo Cable sending unit... Does anyone know if this is just an O-ring problem or how to fix it? |
Re: TH400 Leak
it will have an oring on the outer part of the housing and a seal were the gear comes through the housing. Either one of those could be leaking.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
#3 | |
Re: TH400 Leak
Not to high jack but, this might help the OP. Does anyone have part numbers for these O rings or know where to buy them? |
Re: TH400 Leak
Gm part number for the inner was 1240382 and the outer I believe is a 15562374. Not sure if they are still available from gm or not.
Re: TH400 Leak
Wow. Thanks guys! You are all awesome! I'll check and see if I cant get manufactured O-Rings. If not, I'll figure something else out. I really appreciate your willingness to help to the extent of even getting me part numbers!
Chance
![]() Join Date: Sep 2001
Re: TH400 Leak
Check to make sure the speedo gear itself isn't hallow all the way through.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
