03-25-2016, 11:27 PM | #1 |
How do '86 k30 front springs differ from the '88 V30's?
I am thinking about putting an add a leaf into my current front spring packs on my '88 V30 and I see alot listed for up to '86 & '87 being one part number and the add a leaf kits for the '88-91 V series are a different part number. I just wondered if anyone might know what the difference would be. The reason I ask is because there are fewer manufacturers for my '88 and Summit sells a Skyjacker add a leaf kit but lists it for useon vehicles up to '86.
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
03-26-2016, 01:12 AM | #2 |
Re: How do '86 k30 front springs differ from the '88 V30's?
03-26-2016, 07:19 AM | #3 |
Im not 100% positive, but from what I remember the leaf spring mount bolts are a different size. For an add-a-leaf I don't think there would be any differences.
03-26-2016, 06:46 PM | #4 |
I might just need to call the company and see why the difference in part #'s then. I installed a set of Skyjacker 2.5" softride front lift springs over a year ago. Skyjacker guaranteed them to lift a big block truck 2" and a small block 2.5". They did lift my BB exactly 2" on day 1 but a year later I think they have settled about a 1/2" more. I thought an add-a-leaf may work to help the spring pack that's already there.
03-27-2016, 06:28 PM | #5 |
from what i found on ORD is that 88 and up they used metric bolts so the bushings are different, the springs are the same.
1987 v20 regular cab - work in progress swapped in a (1992 tbi 350 with vortec heads) old motor. currently has an 8.1l and 4l80 swap. flatbed bed 2 inch lift and 64 inch spring swap in the rear. 2002 chevy 2500hd extended long- blackbear tune. DD |
03-27-2016, 08:54 PM | #6 |
Have you thought about an ORD zero rate? It would keep from stiffening up your front springs, which you may or may not be going for.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
