![]() Join Date: Jun 2006
10 Bolt Upgrades
After just looking up a new 12 bolt for my S10 I'm thinking maybe just doing upgrades like stronger axles and the Ultimate cover. The F Body guys are saying the stock S10 10 bolts can handle 350-400HP without sticky tires and using the Ultimate cover with studs, would adding aftermarket axles improve it to 550-600HP without sticky tires?
Should I just have a 8.5 10 bolt narrowed since the 4x4 version is so wide [S10 4X4]. I'm not going drag racing but the thought of having a stock looking S10 with a turbo/4.8L LSx intrigues me.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
mini truck racer
Re: 10 Bolt Upgrades
Well I have done it every way you can do it . If you are lucky enough to to find a factory 8.5 2wd they work good . Weld the tubes to the housing . they have G body ends so c clip elms are easy to get and 30 spline and a 8.6 gear .
9 inch ford .......easy to build cheap if you do your homework . I even did the Camaro 28 spline posi and aftermarket shafts in a 7.625 later model factory rear . I seemed to lose the pinion bearings on the small axle . I will never build another 7.5
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Registered Truck Offender
All I can offer is remember, only a rich man can afford to buy cheap parts. .....
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#4 | |
https://www.google.com/webhp?sourcei...end%20in%20s10
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
I was driving behind a jeep something or other late model and do they have dana 44's in them? it wasn't the Patriot or the other junk models but the bigger 4 door versions. We had one at the shop once and remember the axle shafts being quite thick.
9 inch ford with 35 spline axles and a spool. Their is a guy on ebay that is reall reasonable and gives great service.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
A buddy of mine has an 8.5 in his S10 blazer. Runs a Moser 35 spline spool and their axles. Has 640hp (without nitrous) 421 small block. Runs 10.20's off the bottle, with a tranny brake. 3 years now.
Just FYI, yhe V8 powered Trailblazers/Envoys have an 8.6 rearend, along with some versions of the Colorado/Canyon. They may be a little wide for your app. It's worth taking a tape measure to junkyard. BTW, they're 6 lug axles.
60-66 Nut
To my knowledge, the Trailblazer SS's all have 9.5" 14 bolt differentials. I believe those are the only Trailblazers with V8's.
#10 | |
The only posis for the 8" are the oem G80 and the Eaton/Detroit Truetrac. |
![]() Join Date: Jan 2003
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
meowMEOWmeowMEOW
We've blown at least (7) 10-bolts behind our WS6. At around 350hp, a stock 10bolt frowns. You can use the girdle/brace for the housing which will help the external strength, but it will only do so much. The case itself is actually sorta weak.
We have a large girdle/brace for the f-body 10bolts (has the bracket fit for the fbody) if youre looking for one. I'll have to double check which brand. (T/A or AAM I think). Its brand new.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
i did a 8.5 10 bolt rear in my 1985 c10. i had it narrowed 11.5" and welded the tubes and replaced the 28 spline and upgraded to a 30 spline axle (88-up), i used moser axles, auburn diff. w/ LS and 3.73 richmond gears with the moser rear cover. i was told it could hold up to 600hp. i have not used it yet.
