Old 03-27-2016, 08:12 PM   #1
yossarian19
AWD on a 55-59?
Of all the ideas I've kicked around for what to do with the Truck next, this is one I maybe like best.
Get an AWD transfer case / trans out of a newer Chevy, bolt in a Dana 44 front axle with drive slugs instead of hubs, adjust rear suspension to match height & have an AWD 1957 longbed with stick axles.
Anyone heard of / seen anything like that? I have no idea how i'd expect it to drive. Make me smile, though.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 03-27-2016, 10:51 PM   #2
_Ogre
_Ogre's Avatar
Re: AWD on a 55-59?
do you want it ready for Clay to drive it or not ???
JUST FINISH THE TRUCK DAD!
shop air compressor timer
Old 03-27-2016, 10:58 PM   #3
yossarian19
Re: AWD on a 55-59?
Hehehahahahah!
Hah!
And Hah again!
I'd forgotten about that picture. Man, time flies - he could probably climb up there himself now.
I finally got motivated and moved the MC / booster to the firewall. Ugly but practical. Brakes are 2/3 plumbed. Rear axle is leaving a lot of oil in the drum so I might / might not fix it or put a 12 bolt back there some time.
AWD can wait - I want to get this back on the road so I can enjoy it before temps hit 100+ around here and I stick to the car with AC.
"Over my head"
Old 03-28-2016, 05:50 PM   #4
Russell Ashley
Russell Ashley's Avatar
Re: AWD on a 55-59?
Do you know anyone who has a straight axle 4X4? If so, ask them to let you drive it and then see if you still want to do it.
Russell Ashley is offline   Reply With Quote
Old 03-29-2016, 11:35 AM   #5
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: AWD on a 55-59?
might not be bad. my DD is a f250 4x4 with a straight axle. drives like a truck!
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 03-29-2016, 12:21 PM   #6
yossarian19
Re: AWD on a 55-59?
My DD is a 2004 Grand Cherokee, stick axles on both ends but it's a coil sprung suspension with lots of rubber bushings.
Thinking about it, being AWD wouldn't change a lot in terms of handling. It'd still be a pig, but now with more traction.
"Over my head"
Old 03-29-2016, 12:52 PM   #7
mphudak
Re: AWD on a 55-59?
I've had a few straight axle 4wds and like they way they handle, but I had tweaked the suspension setup for my needs (rock crawling). Time put into the proper spring rate and good shocks goes a long way for handling. If you go this route, you might put a call into deaver springs and have a chat with them about what they can set you up with. Would be money well spent and isn't all that bad to get custom springs.
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
