Engine Harness thru Floor/Firewall
Just wondering if some of you could post pictures of grommets or sealing when passing large wire harness thru the floor in particular. Would just like to see how you all are sealing the pass thru
I'm running Ls with GM Performance Wire harness.
1950 3100 5 window |
Hollister Road Co.
Re: Engine Harness thru Floor/Firewall
We did the same and made a pass through of sorts. It was a 3x3 square aluminum plate. Cut a 1.25" hole with a hole saw and then cut the plate in half. Lined the inside edges with rubber hose and then filled the opening with Black RTV. I was going to use a real bulk head connector until I read in the instruction that you should not shorten or modify some of the wires, I think due to a specific resistance requirement on certain wire like O2 .
![]() Join Date: Aug 2012
We ended up cutting the plugs off and just passing the wires through round grommets so that the pass through holes ended up as small as possible. Re-soldered the connectors to the bare wires once they were through. More work, but cleaner result.
Build Thread: "Marvin" (1953 3100) |
I'm planning on using these for the larger bundles :
'56 Chevy stepside shortbed SBC350 - TH350 12-bolt rear |
The ecm says, "EZ EFI," ironically, it looks anything but that.
I used this one, works great and it has different steps so you can choose what size your final hole is.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Glad to see this topic since this something I too have been contemplating. I have a harness going to an ECM in the cab and I don't want to take the connectors apart, I would rather pass the entire connector and harness through. I prefer a solution where the harness can be pulled back out easily if need be in the future.
I saw this at a show. I thought it was a cool way to finish off a harness passing through a firewall. It's a boat vent. You can find them on eBay of different sizes. ![]() |
#8 | |
Hollister Road Co.
This photo pretty much convinced me I will never have a "modern" electronic engine. Single wire HEI and carb for me....
I've got this one in my eBay cart, not the cheapest...but it is pretty and I like the functionality.
http://www.ebay.com/itm/272275827081 |
#12 | |
![]() ![]() Join Date: Nov 2008
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#13 | |
Does your seat lift for easy access?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
thanks guys, I was not wanting to disassembly the harness and was thinking of some sort of hatch like dwcsr suggested was also looking at
seals it split grommet.
#15 |
Hollister Road Co.
here is a picture of mine, The only thing I would do differently is make a drip edge over the opening so water can't run in
#16 | |
![]() Join Date: Jul 2012
#17 |
I drill a 2 1/4 hole I think and used painless plug
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 |
#18 |
Correction, I used speartechs plug. See bottom of page
http://www.speartech.com/category_s/1825.htm
#19 |
I've been thinking about using the old fuse block mount and cover that goes on the firewall of 48/50 trucks to cover the hole the harness comes out the firewall through I still have the stock cover I had chromed in 1973 in good shape in my storage cabinet.
That boat vent thing looks good and clean though.
#20 |
I ran mine thru the firewall in the fender area using a standard rubber grommet. I filled the space with insulating putty used for construction sealing. It stays in place, but remains pliable if you have to remove it. I also have been using it for metal to metal where the Factory assembly manual shows factory caulking.
