The mother of all stupid questions! Ignition switch hole?
Hey guys! I got a build going over on the "pre 47" side but it's kind of slow over there. So I figured I would ask here. I am in the process of installing the ignition switch into the dash and I need to drill the hole.
Question is do I need to make the hole with the one side straight to keep the mechanism from spinning in the dash when I key the unit? If so how the hell do I make the hole? If I just drill a regular hole will the tightened nut be enough to keep the mechanism from spinning? I have never seen a drill bit with one flat side. ![]() ![]() |
Re: The mother of all stupid questions! Ignition switch hole?
Drill the hole and spot weld in a piece if flat stock on one side?
Yep
Or drill a smaller hole to start and carefully carve it out to fit with a die grinder and a small diameter bur.
What a pain in the @$%#!!!! Is there a better (different) switch I can buy? Maybe I'' just go and buy a half million dollar stamping machine and spend another 75K on the right size die.
Try a file.... it's alot cheaper....
This really is a stupid question.... joking! ![]()
My Build: 57 Chevy Pro-Street |
#7 | |
![]() It's just that after spending 5 years working on something that you never wanted to do in the first place you get kind of burned out dink dorking with stupid $%&@ like this. |
I would just drill the correct size hole and tighten it down good, worked good for me on my '46.
Rob
My '47 C.O.E build |
Well done...that looks great.
1957 3100 ![]() 1950 5 window |
![]() Join Date: Aug 2015
Nice job...I was thinking old school star washer..
I'd say he drilled a smaller hole and did some very neat and tidy work with a couple of files or a dremal tool. Dang nice work no matter how he did it and that switch will never turn in the hole like all too many do in round
file it under patience
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
