Shifter linkage question
Got new column with shifter truck has floor shifter wanna go to column. Engine is 327 2 speed powerglide. Anybody know what i need as far as linkages from tranny to colum?
Re: Shifter linkage question
Bumping so hopefully someone with more experience can help you out.
Not the same problem but.... I had to find a missing part for my clutch linkage and found that LMC has some pretty good exploded diagrams in their online catalog. You might start there. Once you know what your looking for then you can post in the wanted section and Im sure you can find a used complete linkage from someone that has done the reverse swap.
71 swb 350/4sp manual 5/7 static drop |
#3 | |
check out Kugel Komponents. they have what you need for linkage. I have it on 2 of my vehicles
Lokar might work, check theirs out. If you ever plan to do an overdrive trans (I WOULD!) now might be the time as you are redoing linkages as well.
