Radiator fittings for trans cooler lines???
Ran into a problem with my LS swap on my 87 Suburban.
I don't have the correct fittings to attach my transmission cooler lines with 6an connectors to my radiator. Using an Enytopy radiator by the way.
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
![]() ![]() Join Date: May 2015
Re: Radiator fittings for trans cooler lines???
You'll have to know what size/threads those bungs are..if you don't know contact them to find out what you need,, would be my suggestion.
Most are 1/2-20 straight thread, I've used 6an to 1/2-20 flare fittings with an o-ring.
Qwik is correct in that it is straight 1/2"-20 threads but it is also an inverted flare fitting. you'll need something like this to connect it to an AN fitting.
http://www.ebay.com/itm/230894574606...%3AMEBIDX%3AIT |
![]() Join Date: Apr 2005
Whose radiator do you have? Entropy suggest using a 5/16" inverted flare to a 6AN fitting in their radiator.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Jul 2012
Glad to know i was about to order some.
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
