Old 09-25-2003, 11:53 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
205 detents toasted
I have an 87 k-30 with a 205 behind a t400. The detents seem to be completely gone. It will fall in and out of 4wd and also fall into neutral. I have to bungy the thing back in 4-hi to drive it. I know the case is getting tired and ready for a rebuild, but i was interested if anyone knew if there is a quick fix other than a complete teardown.
Thanks in advance.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 09-26-2003, 10:51 AM   #2
Bill W
check this out
Check out this website which is a complete pictorial of how to rebuild a 205. By looking at it you may be able to fiquire out how to fix the detents.
http://www.bulldogs-house.com/Projects/np205/
Bill W is offline   Reply With Quote
Old 09-26-2003, 10:59 PM   #3
kwmech
Check the top of the transfer, the area by the shift rods. A long time ago I saw the screw plugs loosen up and do the same thing.
