Old 04-04-2016, 11:20 PM   #1
Platinum00
Drop question
Sorry this might be a stupid question. I have a 1967 long bed with a 2 piece shaft if I drop it 5" in the rear will I need a drop cross member or should I be fine? Already having a bad day my new wheels will need 1/2" spacer in the rear dang it lol. Thanks for the help everyone.
Platinum00 is offline   Reply With Quote
Old 04-04-2016, 11:24 PM   #2
Platinum00
Old 04-05-2016, 07:56 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Drop question
Your two piece drive shaft should be fine as far as crossmember clearance goes. The problem may be in "length" because when you drop the truck the available clearance in the slip joint is reduced. In some cases binding occurs and pinon bearings, u-joints, and output shaft bearings in the transmission take a beating. A 5" rear drop will require a look at drive shaft end play clearance, and an adjustable or shortened panhard bar, and relocated shock mounts with "shorty shocks" designed for stroke clearance within the available stroke range.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
