Old 04-05-2016, 03:03 PM   #1
encasedmetal
what is needed to incorporate ls harness into stock wiring?
I'm going to be doing a LS swap soon into my 85' C10 and I was wondering once I get my LS harness all made up, what am I needing to do with my stock wiring in my truck. Does the LS harness just replace what's needed and the rest of the stock wiring (headlights etc) just remain in the truck and work fine? thanks for any insight I just never see this talked about.
encasedmetal is offline   Reply With Quote
Old 04-05-2016, 04:07 PM   #2
solidaxel
solidaxel's Avatar
Re: what is needed to incorporate ls harness into stock wiring?
Your L S will be a stand alone harness, with a switched 12VDC and a constant 12VDC
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-05-2016, 06:35 PM   #3
mongocanfly
mongocanfly's Avatar
Ditto to what solid says..the ls stands alone just be sure to ground everything ( motor to frame, body to frame, motor to body, of course battery to motor..) you can't have to many grounds, but on your truck side harness you will still need power as well so dont forget to hook that back up to. I used the big red wire from the hei for my switch on power, the original starter wire from the key went right back on the ls starter and the hot side wire from the starter went back up to the 2 pole connector on firewall above distributor and that should keep all your truck electrical working and that's where I picked up my constant power.
Old 04-05-2016, 10:27 PM   #4
Robznob11
Robznob11's Avatar
Yea your ls harness will have a battery hot, ign hot, ground, fuel pump,tac, tcc brake, and vss, if your lucky it may have e fans depending on who built it. The battery power should feed relays one for ls harness main, and one for fuel pump relay, you should have a minimum of 4 fuses to run your injectors and other . You can tie it in but it's best to Lear it stand alone less mess to chaise later.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-05-2016, 10:39 PM   #5
solidaxel
solidaxel's Avatar
That is exactly where I tied in my Hot and Switched
Temp gauge to pass side head
Oil sender to by pass in LS
Starter to ing. switch, same location
Alt lead went to the Alt
It really is that a plug and play system !
LS 3 4L70E
Old 04-06-2016, 10:49 AM   #6
encasedmetal
thanks so much everybody- this is exactly what I needed to know
Old 04-09-2016, 06:49 PM   #7
suburban99
suburban99's Avatar
Here's a pic of my '62 under the hood. I kept the stock harness and just added what was needed for the LS to run. 4 fuses and 2 relays, diagnostic port, and the PCM of course.
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 04-10-2016, 08:00 PM   #8
LongC'67
Thanks for starting this. I'm curious myself. I'm to the point on my build where I'm asking the same questions. Just had my stand alone built by Modern Vintage in Indiana. I'll be following this for sure
LongC'67 is offline   Reply With Quote
Old 04-12-2016, 07:18 AM   #9
encasedmetal
How are gauges like oil pressure and coolant temp tied in? Do you have to go aftermarket for gauges to read what the LS sensors are reading?
Old 04-12-2016, 10:09 AM   #10
suburban99
suburban99's Avatar
I went with aftermarket because my 62 only had idiot lights. I just changed my fuel tank last week and have not hooked up the fuel gauge but I know it's a 90 ohm and the gauge is 30 ohm. I will probably use a potentiometer to correct.
2015 Ram 4x4 1500
1997 Boxster.
Old 04-12-2016, 05:34 PM   #11
mongocanfly
Mine had idiot lights to. I went with mechanical gauges also. The ls harness reads of the sensor on driver side head. I drilled and tapped the passenger side head for my temp gauge,, on the oil sender I used the autometer adapter to go from metric to standard npt and hooked my gauge to it.
Old 04-12-2016, 07:18 PM   #12
badherb
badherb's Avatar
although I have yet to accomplish my wiring for my LS in the 60 I will be using this guys site and his help for programming my ECM. He has a bunch of info that could be very useful.
http://lt1swap.com/2000harness.htm
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 04-12-2016, 07:39 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^ Lt1swap is like a default resource for swap wiring. 70% of wiring questions can be solved with like 15minutes on the diagram sections over there.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
