04-06-2016, 10:07 PM | #1 |
70+ ( Old Skool Club )
Valve Cover Gasket Choices
I need to replace my valve cover gaskets and am wondering if anyone has used the Fel Pros in my link or I'm open to any other suggestions.
http://www.fmmotorparts.com/fmstoref...t#.VwXAHWO4J0c
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-06-2016, 10:22 PM | #2 |
I need to replace the valve cover gaskets on my truck ,72 C10 with stock 350, and was thinking of these in the link. Has anyone used these and if so how good/bad are they. If someone has a different choice please
post.http://www.rockauto.com/en/moreinfo.php?pk=128425
04-06-2016, 11:15 PM | #3 |
Scrapper 1
Re: Valve Cover Gasket Choices
I just put them on my 1965 3/4 ton stay away from cork that old technology.You will spend 39.00 to 50.00 a set But well worth it
04-06-2016, 11:59 PM | #4 |
Moderator
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-06-2016, 11:58 PM | #5 |
Moderator
Those are the only gaskets I use. Perma dry plus. Just installed a set on my 68 a few days ago in fact. Expensive but worth it...no leaks. No sealant required...just torque to 3ft lbs.
04-07-2016, 01:56 AM | #6 |
I use the Perma dry plus as well. No problems to report. I believe they are supposed to be reusable; Although, I have never reused them.
1969 GMC C/1500 LWB Wideside 355 SBC/TH400/3.73 posi-traction Daily Driver. Carburetors, because I don't care to consort with that of the robot race. |
04-07-2016, 01:59 AM | #7 |
I also have these and haven't noticed any leaks.
'71 K1500 Short-Wide |
04-07-2016, 01:11 AM | #8 |
Had great luck with these and my new aluminum covers. http://m.summitracing.com/parts/fel-1604
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
