![]() Join Date: May 2014
Adhesive molding clips nightmare
I'm sure I can't be the only one having this problem, but today I was hoping to finally install the molding on my truck (Upper and lower, from LMC) Well, first of the molding is garbage (should have gone with Mar-K) but the worst part is those stupid adhesive molding clips they supply. It is damn near impossible to remove that protective film they apply. No matter what I try, it is also removing the adhesive along with that film, making the clip useless. I've tried a razor blade, a pin, even a heat gun.
I sent LMC a nice email, but I really don't expect them do do anything. I sometimes wonder if the Chinese do these things intentionally, and sit over there just laughing at us Here is what I'm dealing with
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
![]() Join Date: Jul 2015
Re: Adhesive molding clips nightmare
When I bought my truck 10 years ago on side on the bed had been redone with that same stuff.
It fell off within 6 months of me owning it. It is still sitting in the garage. |
![]() Join Date: Oct 2009
Ledzepp recommended to me awhile ago - toss the provided gooey ones and use 3M trim adhesive tape. Worked well. The provided clips, even if you do manage to get them installed ok, often fall off in short order as the adhesive sucks. Maddening!
It was a little painful - you need to decide (if you go the 3M route) if you want to just stick the double sided tape onto the existing sticky side of the clip - or scrape it and apply to the plastic back of the clip alone. I did the latter, provided a tighter fit to the body that way. Trim sure looks good, but is a pain to get right. I feel your pain... Went thru the exact same mess with my 71. |
Thanks, I was wondering about using my own double face tape. I'll pick up so e of the 3m stuff and give it a shot. I wonder if my problem is because I bought this molding kit about a year ago. I know how some masking tapes become kind of useless over time. Maybe it's the same for this tape
No, it sucks out of the box brand new. Mine sat for a few days before I used it and it was still useless. Make sure to get 3M, it is worth it.
The 3m stuff is the shiznit... I use it a lot in homes for my security systems.. it'll stick to just about anything
I use Lexel however I got my zen master on using it, it took a while to get good at it.Stuff will even stick to wet surfaces it's some wild $tuff.
I pucked up some of the 3M tape and it worked out great. I just had to make sure all of the old adhesive was removed from the clips, so after I scraped off what I could, I then sanded with some 80 grit to be 100% sure. All molding is now nstalled. I just wish I would have went with the molding tape for the tailgate trim too
Glad to hear it worked out. Yes, it seems we all do this once, but only once! Ha.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Did GM use adhesive when the trucks were built? Can't you just get new clips and forget the adhesive?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#11 | |
![]() ![]() Join Date: Feb 2009
I have NOS moldings, and I listed all the fasteners that came in the packages. In a nutshell, I don't have to drill a hole for the 3M clips, of which there's a bunch.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Moderator
![]() Join Date: May 2007
72 used adhesive style clips on the upper bed moulding. 71-under used metal clips that fastened via drilled holes. I believe the LMC catalog shows the layout. I used 3M adhesive tape as Jocko described above on my 72 and they are still holding strong.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Just want to add my opinion on this topic that I think the adhesive style molding was a major improvement over the through-hole type molding clips on the C- Series. Unless maybe you live in the high desert or Arizona or somewhere super dry.
In fact I don't see what was wrong with a plain steel pickup body with no molding at all in the first place.. "it is just a pickup" as Bruce has so fundamentally pointed out. I'll admit those adhesive clips are also a pain but if you just use a heat gun and plastic spatula judiciously you can remove and replace them reasonably well. It is still a pain of course but not as much as having sixty holes through all of your body panels (as in pre 1972) each one of which (those holes) attracts dirt and road salt in all those places through the body panel where it is out of sight under the molding (until it is too late). Since I just have a work truck at the moment I ended up removing all of my CST-10 molding (to storage) and putting stainless steel button head allen headed machine screws in each hole with nylon washers and nylon lock nuts on the back side to keep the dirt from getting in through those holes. It is not correct of course and not for everyone but okay with me for now. It is easily reversible and that is the main thing. |
Love it again, Gromit! Fabrication the real way!
#15 |
Resurrecting an ancient thread to avoid creating a new one:
I just received my Mar-K lower molding set for my '72 K5. I'd REALLY like to avoid drilling any holes (with the possible exception of the front and back screws). Has anyone tried using ALL adhesive clips and no through-bolts? Even better, has anyone tried just using the 3M adhesive directly between the trim and the body (no clips at all)? Thanks! |
#16 |
The clips work really well IF you remove the adhesive and use 3M tape. On short pieces I just used the tape but there is not much meat to stick the tape to, I ended up cutting the tape in half lengthwise and attached it to the upper and lower edge. I didn't think it would look good on the long pieces since you can see the tape or the gaps between the tape, that's why I would recommend the clips. But whatever you decide to do, be assured the 3M tape really sticks very well, you will not be able to pull the molding back of once it is attached.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
#17 | |
Mar-K is good yet you have to be a craftsman to make it work also. I have seen some of their product installed from someone on the site and I see his frustration also. Get the metal clips, you will be happyier in the long run. |
