09-26-2003, 11:29 AM | #1 |
Big Knock in enigine Bottom end?????
My buddies truck just broke down!! He is in the dark ages so I thought I'd ask the pro's for him! Just wondering if any one has any idea what the problem could be????? The moter blew a gasket and spit the oil out on the highway. The motor still runs fine, but makes a loud Knock Knock Knock Knock !!!!!!!Knock!!!
Any Ideas??
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
09-26-2003, 11:31 AM | #2 |
sounds like he spun a main bearing and it's worn into the crank. This causes the connecting rod to knock against the crank since it's loose now.
Just my guess
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
09-26-2003, 11:38 AM | #3 |
Inline 69
i had a connecting rod "wrist pin" go bad,,,my knocking noise on deceleration,and idle only,,like you said the motor ran fine,,no noise under load
09-26-2003, 12:34 PM | #4 |
It knocks at idle and when you drive it! We drove it home about 15miles and nothing changed same knock while it's running!
09-26-2003, 12:40 PM | #5 |
CCRider
It won't be long before he finds the problem...it will be sticking out of the side of the block
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
09-26-2003, 02:35 PM | #6 |
Either look for another engine or tear it down now. If you keep running it - it won't be for long.
1968 Chevy - 292 with a powerglide |
09-26-2003, 02:36 PM | #7 |
Designated A-hole!
Stick a fork in it it's done! All he's doing now is circulationg bearing material throughout the block. Park and rebuild!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
09-26-2003, 03:04 PM | #8 |
KEEP ON TRUCKING
time for a rebuild a rod thru the block is not a nice pic
72 cheyenne 2wd lwb 71 k20 sons bassett va |
09-26-2003, 03:15 PM | #9 |
Thanks guys!
He just called and he took the oil pan off to see if it is a 4 Bolt Main so he doesn't get ripped off! I told him to rebuild it himself but he is worri!! Time for a rebuild Book!LOL Cheers
09-26-2003, 03:58 PM | #10 |
It will need a crank for sure, and if it is a main that spun, the block will be toast as well. I wouldn't get my hopes up until I determined the source. It may need to be completely replaced....HHHmmm good time for a ZZ4???!
69 GMC K10 ..some restoration required....still.. |
