04-07-2016, 04:53 PM | #1 |
WANTED: Orig 66 TH400 dipstick.
The end of my trans filler dipstick broke off at the kink. Luckily, the end piece flaked off just after I extracted it from the tube. Now I'm looking for an original/correct one in good shape.
04-08-2016, 11:17 PM | #2 |
Re: WANTED: Orig 66 TH400 dipstick.
Can you post photo of the one you need? Application is SBC?
This is a common problem, often they crack and leak. Les |
04-09-2016, 01:35 AM | #3 |
Chevy guy
Why do they do that? Mine is broke off too and unfortunately is sitting in the bottom of the tube in the transmission. I guess I will drop the pan and retrieve it and find me a new dipstick.
04-09-2016, 01:41 PM | #4 |
Not sure about the year! I believe it was 67 or older 26 1/2" long (Top ring to tip). I will try for better photo's if this looks close...Ed
04-09-2016, 03:27 PM | #5 | |
04-10-2016, 08:48 PM | #6 |
They crack and/or break because of vibration. The metal develops stress cracks, then failure. Probably the wrong type of metal was used.
Les |
04-12-2016, 10:40 AM | #7 |
Thanks for the early response. So, that stick looks like it's an inch longer than mine from the stop to end, right? (23-1/4")
04-12-2016, 12:38 PM | #8 |
Bottom of stopper to tip 23 5/8...Top of metal cap over stopper to tip 24 7/16.....$48.00 for the whole thing tube and dipstick...Ed
04-11-2016, 08:01 PM | #9 |
Heres an NOS one Bruce so you can compare GM Part number. Original number was 3905449 changed to 1387568 and again to 1239014
http://www.ebay.com/itm/NOS-1968-73-...ZWeEGb&vxp=mtr http://www.ebay.com/itm/NOS-1968-197...1UREK4&vxp=mtr They are the same as Cars with TH400 so I have several extras used if you need one
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
04-12-2016, 10:36 AM | #10 |
Thanks for the info, Jon. Message coming.
