Old 04-08-2016, 08:51 PM   #1
OldChevy61
OldChevy61's Avatar
Torsion bars
I have a small dilemma. I redone the frame,replaced all steering parts. Torsion bars were marked when removed left and right. I am about ready to install the engine and set the cab back on. Torsion keys are basically all the way down and just noticed one side is very stiff, the other not so much. I can stand on the frame and bounce the drivers side, passenger side not hardly at all. Seems one side needs to come back out and be turned a notch. Which one would be correct?
OldChevy61 is offline   Reply With Quote
Old 04-08-2016, 09:09 PM   #2
Joe Pass
Joe Pass's Avatar
Re: Torsion bars
Here a shot of mine with the full weight on it, adjusted so the bottom a frames are close to levelName:  DSCN2617.JPG
Joe Pass is offline   Reply With Quote
Old 04-08-2016, 09:14 PM   #3
Joe Pass
Joe Pass's Avatar
Re: Torsion bars
Here's a thread that I did on sway bar installation
http://67-72chevytrucks.com/vboard/s...d.php?t=659224
On page three is a good shot of my torsion keys and how I gained more clearance with them
Joe
Old 04-08-2016, 09:24 PM   #4
OldChevy61
OldChevy61's Avatar
Re: Torsion bars
Right now both sides are cranked up evenly but one side is very stiff, the other has a lot of spring. There is no weight on the frame other than the frame itself. The tip of the adjustment bolt is flush with the top of the nut on both sides, so basically all the way down. I'm thinking the side that is really stiff needs to come back out and turn one notch to take tension off that side. Also there are no shocks on the truck yet.
Old 04-08-2016, 09:34 PM   #5
Joe Pass
Joe Pass's Avatar
Re: Torsion bars
I'm thinking that the soft one needs to have more tension....normally you can't flex it with just your weight, it needs about 1500 - 2000 lbs "full weight" on them adjusted about level then you can bounce it....I couldn't do a final adjustment on mine until the finished weight. It settle a bit more after that.
Old 04-08-2016, 09:46 PM   #6
OldChevy61
OldChevy61's Avatar
Re: Torsion bars
Thank you sir. I just wasn't sure which side needed to come back out. That side is rather soft. I want to fix that before motor and trans go in and cab goes on while its easy to get to.
Old 04-08-2016, 09:45 PM   #7
Joe Pass
Joe Pass's Avatar
Re: Torsion bars
Here is my set up ready to install and the engine weight aided me to connect the spindle but not with out a fight....good luck, also you can always go back and switch them when the weight on with out to much trouble
Old 04-08-2016, 09:52 PM   #8
Joe Pass
Joe Pass's Avatar
Re: Torsion bars
I remember me and a buddy standing on the frame horns when it was a completed roller with engine/ trans installed. We were jumping up in down trying not to fall off to see them flex....It wasn't pretty and there was beer involved...
