Old 04-10-2016, 10:56 AM   #1
66clow
66clow's Avatar
Could a bad ignition switch cause this problem?
I'm using this video as a sample of what my truck is doing. I've tried to shim the starter but it still gets hung up on the fly wheel or just spins. Starter is new on a chevy 350. You can jump ahead to the 2:45 time on the video. I've had to do the rush to battery dance as well.
https://youtu.be/hXjYF5otyXk
66clow is offline   Reply With Quote
Old 04-10-2016, 11:30 AM   #2
old Chevy guy
old Chevy guy's Avatar
Re: Could a bad ignition switch cause this problem?
I won't say it can't be the switch but I doubt it. More likely the starter or the solinoid is junk. More likely the solinoid. Just because it's new doesn't mean it can't be bad. If it's new from the store exchange it and see what happens. that what I would put my money on.
old Chevy guy is offline   Reply With Quote
Old 04-10-2016, 12:07 PM   #3
A1971Blazer
A1971Blazer's Avatar
the only way that the switch could cause it.........if it's sticking in the start position or is shorted in the connector....I've seen them with melted connectors
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 04-13-2016, 07:11 AM   #4
A1971Blazer
Hmmm..........anything is possible on these old trucks.....
1967 C10 Step side
1968 C10 Step side
Old 04-10-2016, 12:20 PM   #5
JDL
JDL's Avatar
that is the starter Bendix slipping
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 04-10-2016, 12:58 PM   #6
geezer#99
geezer#99's Avatar
Do you have the correct knurled shoulder bolts and a starter brace?
What ignition?
Is it points or hei?
geezer#99 is online now   Reply With Quote
Old 04-10-2016, 01:30 PM   #7
66clow
66clow's Avatar
What ignition?
It just has the new bolts with the starter. Not sure if hei. Here are photos of the engine. No brace. Bought truck with from po. Tuck was just converted from long short. Truck was just put back together and I know the po fooled with the timing a bunch of times trying to start it, turned out to be a bad carb. I bought a carb to get it running. But this was after many attempts of hearing the starter spin and getting hung up. So that is why I'm thinking the new starter got jacked up or the switch went bad from the numerous attempts.
Old 04-10-2016, 02:26 PM   #8
In The Ten Ring
You do plan to redo your fuel lines there before the carb right? I'm not sure if I'd want a plastic fuel filter and hoses resting right on the engine.
In The Ten Ring is offline   Reply With Quote
Old 04-10-2016, 02:33 PM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Exactly. I did the same thing once and rec'd a lecture from a mechanic. Hard-line only, and if you choose an auxiliary filter it best be steel raised off the engine. I just use the filter at the carb. It's cleaner and works as intended.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 04-10-2016, 02:42 PM   #10
66clow
66clow's Avatar
Yes, thanks it is on the works. Did it to get it running but not road ready.
Old 04-10-2016, 01:15 PM   #11
davepl
davepl's Avatar
Starter/solenoid or flexplate or the mating of the two.
Did you have the engine out? Is it possible you put the flexplate on backwards? That'd be your worst case. I've seen it before.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-10-2016, 01:47 PM   #12
66clow
66clow's Avatar
Talking Re: Could a bad ignition switch cause this problem?
That's something to think about. Would it still start our line up? Im going to check to see if the spacing is correct between the starter and flywheel. The po did the swap. But it was definitely out.
Old 04-10-2016, 01:42 PM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Disconnect the purple wire from your starter and the yellow wire if you still have it on the starter.
connect a starter jumper between the large cable on the solenoid and the small S wire terminal.
Disable the ignition coil or distributor so it can't start the engine.
Now press the jumper button on the starter jumper and engage the starter.
This eliminates the problems from everything but the starter and the solenoid.
Timing,. poor conductivity on the S wire, bad ignition switch, etc.
If you still get the problems then your starter solenoid is weak or shimmed incorrectly.
Refer to my thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=655903
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-10-2016, 01:53 PM   #14
71CHEVYSHORTBED402
Seems these guys are on the right track. Did you shim the starter? If you ask me, it needs to be closer. If it grinds then it's too close. My guess is it's the solenoid, but I would remove a shim first.
On a side note, if that were my Corvette there would be a lot more padding on those fenders.
Tony
Old 04-10-2016, 02:05 PM   #15
66clow
66clow's Avatar
Also I did take the starter to autozone to test it. It operated fine with no load on it but I'm still thinking it could be bad once you put the load on it. I tried a few shims but still had problems. I didn't try shimming just one side to get it closer or further away.
Old 04-12-2016, 11:23 PM   #16
Dimebagdavesc30
Dimebagdavesc30's Avatar
I had a 77 chevy c1500 with a 350 I bought with the starter and flywheel that wouldn't mesh right, made an awful sound when starting, but started. I was getting the lifetime starter and flywheels from a chain store, three starters and flywheels later all with in a year, I just kept taking them back. So I took the final new in the box lifetime starter to my favorite salvage yard and told the guy, I would trade him even up for an old starter off a junk truck. Once installed I never had a problem again. The lifetime starters I could never get to work without the awful chirping noise......and eating flywheels.......
Dimebagdavesc30 is offline   Reply With Quote
Old 04-13-2016, 07:56 AM   #17
67 chevelle
67 chevelle's Avatar
The correct spacing between the starter gear and flexplate is when an end of a paperclip wire will fit between the gears when they are engaged
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-14-2016, 10:50 PM   #18
71CHEVYSHORTBED402
I'm fairly green though I've replaced a few starters. How do you know when they're engaged without starting the ignition?
Tony
Old 04-15-2016, 02:00 AM   #19
66clow
66clow's Avatar
Mine was actually getting stuck on the fly wheel. You either look underneath at the starter or the starter continues to run after the vehicle starts and you will likely see smoke boiling out from your battery cable.our possibly some other wiring. Not a good situation you have to make a mad dash to disconnect the battery before the vehicle goes up in smoke. Not something you want to experience.
Old 04-15-2016, 02:52 AM   #20
67 chevelle
You have to take off the gravel plate and get under the truck with a screwdriver and engage it
Old 04-13-2016, 01:02 PM   #21
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Glad you figured it out and thanks for the feedback.
VetteVet
Old 04-13-2016, 01:04 PM   #22
old Chevy guy
Defiantly didn't see that being it. Would have bet the farm on bad solinoid or bendix. Like 71Chevyshortbed402 said thanks for the update. I hate when you follow a thread to see what really happened and you never find out. It's like when your favorite show ends the season in a cliffhanger and the show gets cancelled before the next season.
