04-10-2016, 11:43 PM | #1 |
Temp gauge not working
Another question for the masses. I noticed today that my temp gauge is not working. The needle is pegged out past hot. The wire from the block to the firewall is intact so I'm thinking, again, that the connects are corroded or it just got knocked loose under the dash. Another thing added to the to do list.
04-11-2016, 11:19 AM | #2 | |
Re: Temp gauge not working
1971 C10 Cheyenne Super Build Thread Here: http://67-72chevytrucks.com/vboard/s...d.php?t=411867 |
04-11-2016, 11:39 AM | #3 |
Something somewhere is grounding the green wire. Could be the sender, could be a short elsewhere. But the gauge, if not defective itself, is seeing ground or close to it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-11-2016, 12:22 PM | #4 | |
Msgt USAF Ret
Pull the wire off the sender and watch the gauge. If it stays hot the gauge wire is grounded or the gauge has gone bad. also Ohm the sender as said above with the engine cold, and if you get low ohms between the sender wire connection and the sender body, the sender is kaput.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-11-2016, 03:09 PM | #5 |
Thanks to all. I'll test it when I get home. Should be an easy fix
04-20-2016, 08:25 PM | #6 |
I got my gauge working today, it was a loose connector. I replaced the sending unit anyway, since it was the original
