Old 04-11-2016, 09:59 AM   #1
PowerdbyChevy79
PowerdbyChevy79's Avatar
wipers have a mind of their own...
ok. ive heard this is an issue with squarebody's ....every now and then my wipers will just turn and do a couple sweeps by themselves.. wiper switch is new.. don't know whats up with this..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 04-11-2016, 10:10 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: wipers have a mind of their own...
The wipers are a switched ground system. The switch provides the grounds to run the motor not the hot.
Either the park switch inside the wiper motor assembly is out of whack or you have an intermittent short to ground in the HI or LO speed wire from the switch.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-11-2016, 12:36 PM   #3
TKCR
TKCR's Avatar
I replaced my turn signal/wiper/cruise control stalk. After getting the old one completely out, there was a section in the wire, that the casing was completely dry rotted and exposing quite of bit of bare wire. I never would have seen it, it was inside the steering column. Wish I would have taken a pic of it to show, but I just pitched it in the trash.
TKCR is online now   Reply With Quote
Old 04-12-2016, 01:18 PM   #4
PowerdbyChevy79
thx for the help brothers..
1966 C10 "Mary"
Old 04-13-2016, 09:09 AM   #5
Greenlee
Greenlee's Avatar
If I were throwing parts at it, I would start with the motor. It's relatively cheap and easy to replace. I replaced the switch twice thinking I had a switch problem and it turned out to be the motor which was much easier to replace than taking apart the column.
Greenlee is offline   Reply With Quote
Old 04-13-2016, 09:23 AM   #6
TKCR
TKCR's Avatar
I didn't have to take apart my column to change out the switch.
Old 04-13-2016, 10:07 AM   #7
PowerdbyChevy79
ive replaced the switch only.. but its starting to bug me.. so I need to take care of it..
1966 C10 "Mary"
Old 04-13-2016, 12:32 PM   #8
hatzie
Moderator
hatzie's Avatar
Look over the wires first. If they're OK then change out the motor.
Old 04-13-2016, 12:52 PM   #9
bagman
Most likely you will find that the control module for the delay wipers is causing this. It is located below the steering column. Remove the panel under the column and you should see a small black box with wires to either end. I think you can bypass the module by disconnecting the wires and connect both wire connectors together to eliminate the module from the system. You will no longer have intermittent wipers.
bagman is offline   Reply With Quote
Old 04-13-2016, 03:19 PM   #10
MikeB
MikeB's Avatar
If he has an 82 truck, then the switch is on the dash and there is no control module, unless there was an intermittent option back then???
And he can replace switch AND wiper/washer assembly for less than $100.
I've had my wiper/washer assembly torn apart a few times. When I get it back together everything works fine. Then, after a while, whenever I turn on the wipers, the washer starts working and won't stop. My switch is new. I think the entire wiper/washer assembly in $50-something exchange at O'Reilly Auto Parts. Probably less at Rock Auto. That's my next step.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-13-2016, 03:40 PM   #11
PowerdbyChevy79
ya I have a 82..
1966 C10 "Mary"
Old 04-21-2016, 03:58 PM   #12
El Dorado Jim
I had the same problem years ago on my '73, it was a bad motor
El Dorado Jim is offline   Reply With Quote
Old 04-21-2016, 09:19 PM   #13
1774btcrew
1774btcrew's Avatar
The 82 could have had delay wipers. The module would be plugged in behind the switch
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 04-21-2016, 10:00 PM   #14
hatzie
Moderator
hatzie's Avatar
If 78-83 has delay wipers there's no way to mistake em for standard wipers.
Old 04-21-2016, 11:15 PM   #15
barry1982
Ah yes..... this is a very common problem with the old delay wipers.... I have had delay wipers in an 81 and two 82's. ALL of them intermittently just turned on and off. So you guys think it's the module behind the switch.....? Great info... will have to look into changing it.
barry1982 is offline   Reply With Quote
