Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-12-2016, 04:11 AM   #1
BigDan3131
BigDan3131's Avatar
Question Fuel Cell Vent?
So I'm wondering if I need a vent or not. This is not a race truck, strictly street but I'm having a fuel cell built for my truck that works with my space and gives me 32 gallons instead of the common 20 gallon ones. The pump has a return built right into it and will be -8 so I'm guessing a vent should be needed? Should I just use one of those mini breather style or a roll over vent style or one of those mini breather catch cans?
It will have the drag style outlet in -10 and as yet have not decided on the filler cap. Are any of the billet ones available as a vented cap?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 04-12-2016, 08:58 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Fuel Cell Vent?
Yep, you'll always need a vent. For a street vehicle, I wouldn't worry about a roll-over check ball vent. I just run a vent equal in diameter to my fuel supply line with a bulkhead fitting and a filter clamped on the end. It's the black hose with black fittings on the left side of the access panel of my tank that goes toward the driver side frame.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-13-2016, 03:20 AM   #3
BigDan3131
BigDan3131's Avatar
Re: Fuel Cell Vent?
Thank you.
