04-14-2016, 08:19 PM | #1 |
Flip kits offset the axle?
So on my Suburban build I am just welding on spring perches but I did order a flip kit a few years back and the locator hole for the leaf spring pin is offset almost an inch. It looks just like this. I thought it might be to center the axle in the wheel house but mine looks like its in the right place in relation to forward/back.
Why did the offset in the kits? Last edited by gearheads78; 04-14-2016 at 08:25 PM. |
04-15-2016, 10:36 PM | #2 |
Re: Flip kits offset the axle?
The offset is to allow more driveshaft travel. When you install a flip kit, the axle moves upwards. Therefore making a shorter distance from your transmission tailshaft to your differential. So the offset hole moves your axle back to allow more driveshaft movement so the yoke doesn't bottom into your transmission.
04-16-2016, 09:33 AM | #3 |
I just used the Mopar Spring perches. No offset. I wanted to keep the rear centered in the wheel well. I did use a shorter driveshaft. I found one in the junkyard that was 1" shorter. The new driveshaft was bigger diameter and required a hybrid rear u-joint. No big deal though. My stock one was 55 1/2" and the 1988 Chevy 2500 4x4 shaft was 54 1/2". Perfect for me.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker Last edited by 65standard; 04-16-2016 at 09:39 AM. |
04-16-2016, 09:45 AM | #4 |
The Mopar Spring perches
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
04-16-2016, 09:50 AM | #5 |
Another view
04-16-2016, 01:02 PM | #6 |
Do the mopar ones have the right pin hole size? None of the seem to list the size of the hole. I got some from Summit and the hole is too big.
04-16-2016, 04:16 PM | #7 |
the Mopar Spring perches fit the center bolt nut perfectly. Since the axle now sits on top of the springs, I put the center bolt in from the bottom, with the nut on the top, and to mate the nut with the perch hole.
04-16-2016, 04:51 PM | #8 |
I was going to buy the kit in the picture at the top of the thread. So with this kit, the wheels won't be centered in the opening?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
04-16-2016, 05:01 PM | #9 |
Diggin The SquareLife
any flip kit u buy the wheels would be center....
04-16-2016, 06:13 PM | #10 |
The rear is moved back 1" so it is not centered anymore. But it is hardly noticeable.
