04-18-2016, 12:15 AM | #1 |
4 speed swap parts
Hey there everyone. Ive been slowly gathering parts to convert my k5 over from an automatic. Havent had alot of luck finding the conversion parts needed locally. I did find a 73 c10 with a 3 on the tree. A few possible issues tho. Its a 6 cylinder and I have a v8. Also its got manual brakes and I have vacuum. Im pretty sure the v8 zbar is different? Anyone confirm that? Also does anyone know if the pedals from a manual brake truck can be swapped with a power brake truck? Thanks guys
04-18-2016, 02:22 AM | #2 | |
Re: 4 speed swap parts
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
04-18-2016, 08:27 AM | #3 |
Thank you. Im getting a good deal on all the parts so it's worth the risk if they end up being different
04-18-2016, 10:56 PM | #4 |
Well here is a piece of info for you. When I was with GM I learned how GM engineering worked. They would change the part number for the smallest change. up to and including a change in material or manufacturing process. So even though the pedals carry 2 different part numbers they could interchange or worst case be alterable to fit. Personally I have never dealt with a square that had only JB1 brakes. I would bet the only difference is the push rod location is in a slightly different.
04-19-2016, 01:29 PM | #5 |
Perfect. Ill be pulling the parts this saturday. Cant wait to use my a833
04-19-2016, 08:51 PM | #6 |
Robert Olson Transport
there is a difference on the power brake and manual brake set up.. IIRC its something with the size of the holes one wont fit the other.. I ran into this problem trying to find the proper set up for my 74 stepside
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-20-2016, 12:09 AM | #7 |
A few years ago I converted my 82 1/2T 4 x4 700R4 to a "farmer 4-speed".
I got lucky and bought a roll over 81 4 x 4 with a 4-speed. Came in handy having ALL the parts right there. Was a BIG job. Installing the clutch/brake pedal setup was pain, and if I remember right, also had to use the transfer case shifter that came with the 4 speed truck. I also used the floor "hump plate" from the 4-speed truck. |
