04-19-2016, 01:36 PM | #1 |
fuel upgrades for cam swap?
wondering if anyone let me know if I'd need to change injectors or fuel pump with a cam swap. initially going to be using the EP381 pump and stock injectors but if I need to swap some things out I wouldn't buy them to begin with. still deciding between a 5.3, LS1, or 6.0 motor. thanks
04-19-2016, 03:53 PM | #2 |
meowMEOWmeowMEOW
Re: fuel upgrades for cam swap?
Depends on the engine choice and cam choice. The 381 pump is usually fine for most basic setups. Stock injectors are a bit limited, but a 5.3 with a medium cam will survive alright with them. A 6.0 with a huge bumpstick will usually want a bit more fuel than the stocks want to supply, or you'll end up with a large enough duty cycle % that the injectors will not like long-term.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-20-2016, 02:16 PM | #3 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-20-2016, 12:39 PM | #4 |
I would datalog the injector duty cycle before changing them out, but would this pump work in an 87' sending unit? http://www.summitracing.com/parts/gr...t/model/camaro
