04-19-2016, 08:12 PM | #1 |
Dashboard replacement (with pictures)
To make a long story short, what I thought was going to be a wiring project became something more: The PO hacked up the dash installing a billet dash bezel and glove box door. So much so that all of the attachment points for a stock bezel were gone. This kind of craftsmanship really chaps my hide.
So before I could start my wiring project I needed to replace the dash. I found a lot of threads here about how to remove a dash, but didn't find a real project thread. I decided to document the process in hopes that someone will find it useful. First of all: The dash is held on by three bolts on each side, below the A-pillar. Remove these bolts first. That's the easy part. There are also 28 or so (mine had 29) spot welds along the bottom edge of the windshield lip. So the windshield has to come out in order to get at the spot welds. Let me say that I did not intend to re-use the rubber since it was a little old looking, so the method I used to remove the glass involved cutting the old window rubber out. I have read other threads on this forum where the rubber can be removed intact from the inside of the cab. To remove the windshield, I cut around the inside edge of the rubber, deep enough so that my knife hit the rib of the stainless trim. If you don't have the stainless in the window rubber, this part doesn't apply. Just take your time and try not to scratch your windshield, okay? Once I cut all the way around the windshield I was able to gently pull the rubber away from the trim. Once I got the rubber out I was able to remove the corner pieces. It took a little wiggling around, but they eventually slid off. The windshield was pretty well stuck in there so I worked from inside the cab to pull the rest of the rubber out. Get someone to help you take the glass out - it's not heavy, but kind of awkward. So far, so good. The windshield lip and the upper lip of the dash are spot welded together. In this picture you can see the indentations where the welds are. It only takes a few simple tools to remove the spot welds: The Dremel bought the farm about half way through, so I switched to my pneumatic die grinder with a ball-nose rotary file. It's a little more agressive than I liked, but it worked. I decided to work from the dashboard side so as not to put a bunch of holes in the flange that is part of the body. I wanted that piece to stay nice as I planned to pre-paint the new dash and install it with automotive epoxy. More about that in a bit. Carefully grind at the spot weld until you're just through the first layer of metal. Work the flat bar into the gap between the two pieces and whack it with the hammer a few times. Most of the time the weld popped apart pretty easily. Repeat 28 times. Voila! About 2 1/2 hours from start to removal of dash. With the old dash out it was time to prepare the new one. I was lucky enough to find one from a guy who was parting out a '69 (mine's a '70). Sneak peek with about half the paint removed: Some sanding and a little filler to smooth out a few pits on the top and it's time for epoxy primer. I am using Southern Polyurethane products which spray and sand beautifully. More to follow; I'm going to work on the truck for a bit.
Dennis '70 CST/10 '55 Bel Air wagon |
04-19-2016, 08:13 PM | #2 |
Re: Dashboard replacement (with pictures)
I feel your pain.... on the other project I'm working on I was tracing back the tach wire and it was green for while, then crimp connector'd to white, then back to green, and finally twisted to the factory brown wire.
Always nice to clean that stuff up and know it's done right though!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-20-2016, 03:00 AM | #3 |
I hate hackers! , some people should never touch anything,you are doing a great job....
04-20-2016, 06:10 AM | #4 |
72 GMC
How's your wiper motor and pump ?
Pretty easy access right now !
KEL Members I have met : 2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW |
04-20-2016, 12:55 PM | #5 |
Meanwhile, I'm in the middle of this, so I feel your pain. The tach wire started out green, then went white, then back to green, then brown to the tach. Like wire was gold.
I have one car we've had since new and I'm so used to only my own mistakes that the nonsense I've found under here is pretty amazing!
04-20-2016, 02:03 PM | #6 |
Thanks for the replies, gentlemen.
El Dorado Jim - I always wonder why people decide to flail away on these trucks without any care. Better just to leave them alone at that point. KEL - talk about full access! Wiper motor and pump are both good, but I did take the opportunity to clean up the heater/defroster box and put in a new heater core.
04-20-2016, 02:07 PM | #7 |
Sounds like the same guy worked on my truck, Dave. I was chasing a wire from the battery across the radiator, but the color going in to the chase never came out. Turns out it was spliced three times over the width of the radiator! Jeez. That was about the time I realized a new harness was in my future. On the rest of the truck, I think the PO only had red wire because that's about all there was under the dash.
04-20-2016, 03:22 PM | #8 |
Nice write-up so far. Thanks for sharing the steps!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-20-2016, 03:50 PM | #9 |
that was sure a messed up dash. looks like you're doing a great job replacing it. we need more pics. thanks, Larry
04-20-2016, 04:50 PM | #10 |
This is y I now own a parts truck! good Wright up..
04-20-2016, 04:54 PM | #11 |
x2 on the write up. nice pics also.
04-20-2016, 05:32 PM | #12 |
Thanks for sharing this - Nice job on those pop rivets; and it was very helpful that you took the trouble to show the tools used and the windshield removal steps.
It is interesting that sophistication (in work practice) often actually makes a process simpler. For example compare what you just did with this nine-part youtube of a talented guy doing the same thing: https://www.youtube.com/watch?v=2iZIzaFzbro It a C10 truck; but it is a later model; (1977); he ended up drilling a hundred or more holes in the sheet metal across the dash and leaving the two spot welded layers attached, then sawing between the holes and removing the dash, then peeling off the remaining 1/2" wide strip of dash metal that was still attached by the spot welds, then replacing the spot welds with fasteners. He did a nice job and it turned out great but wow your method is a lot more elegant and do-able (now for those of us seeing how you did it) - on a weekend. In my opinion it is a major improvement to make the entire dash assembly modular - (removable by loosening a few fasteners) - both for cleaning and access to other assemblies during repair and maintenance and modifications. Thanks again for your post Last edited by Gromit; 04-20-2016 at 05:41 PM. Reason: not sure whether the youtube guy removed the windshield |
04-20-2016, 06:17 PM | #13 |
Thanks, guys! More to follow.
Thanks for that YouTube link, Gromit. Wow - that seems like a lot of extra work, but just goes to show there's more than one way to get the job done.
04-20-2016, 06:43 PM | #14 |
You don't know wiring problems until you start messing with Mopars. Nice write up. What harness are you going to use?
