View Poll Results: HELP!!!!!
Flat 16ga panel no porterbuilt panel 2 33.33%
Flat 16ga with porterbuilt panel welded flush to the 16ga panel 4 66.67%
Voters: 6. You may not vote on this poll
Old 04-20-2016, 12:10 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Need some opinions
So I'm shaving the firewall on my 73. I was originally going to just fill the holes and got as far as making all the templates. I made the mistake of cutting the lip off of the big hole for the a/c and it made the firewall very flimsy and it distorted some when I welded some of the smaller holes. So I bought some 16ga sheetmetal and got a template made and cut it out. I really like the way it looks now. I bought a porterbuilt firewall plate to graft into the flat 16ga but looking at it now I am torn so I need some help.
Option 1: Flat 16ga no porterbuilt panel
Option 2: Flat 16ga with porterbuilt panel welded flush to the 16ga panel
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-20-2016, 08:50 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Need some opinions
Add the panel, it needs some detail. White Lightning?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-20-2016, 01:05 PM   #3
softballnrd27
Yes a 95 with some work done
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-20-2016, 08:59 AM   #4
cochino12
It followed me home?
cochino12's Avatar
I agree, use the panel
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-20-2016, 09:25 AM   #5
CSHADES
CSHADES's Avatar
Why don't you take the panel you made and add some beads into it with a bead roller instead of welding more metal on top of metal?
CSHADES is offline   Reply With Quote
Old 04-20-2016, 09:33 AM   #6
andrewmp6
Yeah i would bead roll the piece you have or maybe add some extra strips in any design you like.
Old 04-20-2016, 12:52 PM   #7
daddyjeep
daddyjeep's Avatar
The panel or rolled bead will add a little rigidity, so I vote add the panel.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-20-2016, 01:09 PM   #8
softballnrd27
If I use the panel I will cut out the shape of the panel and weld it to the flat panel flush. I don't have a bead roller but I might look into it locally to see if I can find someone that does it.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-20-2016, 04:25 PM   #9
CSHADES
CSHADES's Avatar
Everybody that does sheetmetal work should own a bead roller. They aren't that expensive other than with the cheap ones you usually end up reinforcing it to make it work good. Once you have one you will wonder why you didn't buy one before. I have the one from Horrible Freight it works good after I added a 5/8" thick plate to the rear of it. I am looking to buy the really nice one that Baleigh sells. It is electric and has a quick release/pressure set up on it.
Old 04-21-2016, 01:57 AM   #10
andrewmp6
Call any speed shop or even some 4x4 shops might have a bead roller.
Old 04-21-2016, 01:35 PM   #11
Shugalou
Shugalou's Avatar
I'm a fan of keeping it smooth - I think it would look more showey...and more surface area for stickers
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 04-22-2016, 11:57 AM   #12
Ice&burban
Add the panel, definitely will add some depth to the firewall.
Ice&burban is offline   Reply With Quote
