Old 04-20-2016, 07:07 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
How to pull Steering Wheel 'Hub'?
How do I pull the steering wheel 'hub'? I guess it's called the 'hub', it's the part that the steering wheel bolts onto.
Oh, and the reason that I need to replace it is that the threads are all stripped, so if this involves a puller that 'bolts' into these 3 existing holes, obviously that won't work.
I tried to tap them, but that didn't go so well.
I'm all out of ideas.
'63MurderTruck is offline   Reply With Quote
Old 04-20-2016, 10:04 PM   #2
Big Fenders
Re: How to pull Steering Wheel 'Hub'?
Can you drill and tap the holes to a larger size bolt?
Bob
Big Fenders is offline   Reply With Quote
Old 04-20-2016, 10:27 PM   #3
lowbucktrucks
helicoil
lowbucktrucks is offline   Reply With Quote
Old 04-20-2016, 11:15 PM   #4
Tazimafied
A standard three jaw puller has worked for me before. Just make sure you don't grab anything behind the adaptor/hub.
Then you can install a real steering wheel...
Tazimafied is offline   Reply With Quote
