04-25-2016, 08:02 AM | #1 |
How much sound insulation?
Getting ready to order some Fatmat sound insulation for my suburban and was wondering how much I should order. I plan on doing the roof as well as the sides and floor. Where's the cheapest place to buy it? 100 sqft? 200? TIA
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-25-2016, 07:58 PM | #2 |
What?
Re: How much sound insulation?
I used 3 "trunk kits" from Dynamat just to do the metal floor section, along with two door panels. The stuff is espensive...
My drive train noise still comes through pretty loud, even with a layer of jute padding and MIP layer on the carpet. I took a day long road trip in my burb yesterday, and it was all pretty much highway speeds. Towards the end, I was thinking of ways to make things quieter inside again. My interior noise has lessened considerably since I have added my sound proofing, but I am still looking for ways to make it even more quieter with out having to swap my Rockwell Tcase for a New Process lol.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-26-2016, 06:05 AM | #3 |
What about the spray on lizard skin that is to deaden the sound transfer?
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
04-26-2016, 08:17 AM | #4 |
I was going to try standard rubber (neoprene?) mat on the bed quarters because it should work and was only $10-$20 a roll at the Turkey Rod Run. It was from a place in NC. That commercial sound deadening material is way overpriced IM(ignorant)O.
I was also watching weekend tv car shows that had a one of the sound deadening material guys on selling his goods. He demonstrated that a small piece of material can make a huge difference, so it may not need material completely covering the surface. As far as the amount of the material, it wouldn't be too hard to make rough measurements of all the exterior surface areas. You could almost figure: side length x side height x 2 sides + bed length x bed width x 2 top&bot ~= 10x4x2 + 4x10x2 = 160sqft ... just a wag. |
04-26-2016, 08:18 AM | #5 | |
Good stuff, but hard to apply to a painted vehicle.....
04-26-2016, 10:04 PM | #6 |
BlahBlahBlah
I personally like lizard skin a lot, Ive used it on a couple of trucks. I'm not sure why it matters that your Burb is painted. Isn't everything going to be covered with carpet or headliner?
Same as with the sound mat stuff. It has to be put down over paint, and doesn't it have sticky back?
04-26-2016, 10:13 PM | #7 | |
http://m.lizardskin.com/
04-26-2016, 11:38 PM | #8 |
BlahBlahBlah
I brushed mine on. But you can get a sprayer for it ... Now I understand what you were thinking though. Its kind of pricey, prolly a lot of dough to do a burb. There is a heat version and a noise version ... you can put one over the other (I forgot which one they advise to do first).
I get the use of mat, I just cant get past putting it on the roof of a vehicle ... seems like the heat of the sun can loosen it up.
04-27-2016, 09:40 AM | #9 | |
Rob PS You wouldn't happen to have a couple extra 4" rear seat brackets would you? Some how or another, I ended up with 2 short ones on mine and now I can't mount my rear seat, .
04-27-2016, 11:48 AM | #10 | |
BlahBlahBlah
Yeah I did get rear air ... guess I need to modify my sig. As far as headliner I have OEM and the strips.
04-27-2016, 12:12 PM | #11 |
The Older Generation
Interesting thread. I am getting ready to put something on the inside of the Panel Truck. I was also concerned about the stick on stuff staying on the inside of the roof. It seems like it might start peeling off with the heat. Dunno.... I guess regular spray on undercoating would work too. Auto company's used it on the inside body panels for a lot of years. I need both insulation and sound deadening. LockDoc
04-27-2016, 10:10 AM | #12 |
I work in the pipeline industry and I specialize in corrosion control. I recently met with one of the coating companies about heat and sound insulation on pipelines. I alway look at ways to apply these material in th auto industry. I realized that the parent company for Lizard Skin is Mascoat. And if you can find a sales rep in you area you may be able to buy the same coating as lizard skin at half the price. If you look at the lower left side of the Lizard Skin site you will see the name Mascoat. http://www.lizardskin.com/
http://www.mascoat.com/transfer-pipe...nsulation.html
Pulatoy |
04-27-2016, 10:19 AM | #13 |
Look into a product called Mass Loaded Vinyl. Spendy, but very effective at noise attenuation if installed with a 'barrier.'
I did a combination of things in my burb: I used a roofing product called, peel and seal products on the roof and floors-took 4 or 5 rolls IIRC. On the side panels, I used a DIY lizard skin by mixing elastomeric roof compound and 'micro spheres.' Lastly, I added a 1/8 MLV to the floor. All together, I would estimate nearly 400 bucks into the project--well worth the effort. This does not include the cost of the headliner and the carpet kit.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
04-27-2016, 01:05 PM | #14 |
BlahBlahBlah
Im going with lizard skin on my 72 Burb. I gave my panel to one of my sons (no matter how hard I tried to get back in to that thing I couldn't) and he will be using lizard skin too, especially because its black.
04-27-2016, 04:28 PM | #15 |
Just applied Lizard Skin to the rear section of the suburban after replacing the wood bed with metal. I did not measure db before and after but to the naked ear I would say there is no "significant" difference. (Hard to drown out a 454 Chevy running headers and Flow-masters) Next step is to rattle trap the entire car, and maybe invest in some MIP rubber mats and probably switch to Magnaflow mufflers ;-)
04-27-2016, 06:51 PM | #16 | |
BlahBlahBlah
05-08-2016, 12:24 AM | #17 | |
05-09-2016, 12:19 AM | #18 | |
http://67-72chevytrucks.com/vboard/s...&postcount=154 Really happy with the result but sill going to ditch the flowmasters! Brian |
04-27-2016, 05:10 PM | #19 |
The magnaflows made a HUGE difference. I was so glad to get rid of the flowmasters
05-02-2016, 01:26 AM | #20 | |
What?
I run twin FM series 70's, and they are nice at idle. But at highway speed, they tend to drone. I would like to replace them with a same size muffler from Magnaflow, but it seems all they make are much smaller mufflers even if they are quieter. Trying to avoid making my exhaust system look like a patch work of welds.
05-09-2016, 12:38 PM | #21 | |
You might try the "J" pipes before you replace them. I put them on the Panel Truck with the Flowmaster 40 knockoffs and it made a lot of difference on the drone.... LockDoc
05-16-2016, 07:00 PM | #22 |
We always apply the spray on sound deadener after the vehicle is painted. This way we can paint all the way into the cab with overspray and then make a nice looking finished product with the spray in sound deadener. We use a product called VB1X from Cascade Engineering. You can find it on www.partsexpress.com
I always use the same process on all of our builds. All of this is after the vehicle has been thoroughly seam sealed and epoxy primed: * Mask vehicle * Apply 3 coats of VB1X to the interior surface of any unpainted part. * Apply HD Matt from Cascade Engineering to floor and roof- this product comes in either sheets or rolls and is placed in pieces. You don't need to cover every square inch. Basically, it is installed on the flat pieces. You are just changing the frequency pitch of the metal surface. * Jute matt * Carpet ***Enjoy :-)
Silver Creek Auto Body & Detailing My 70 Chevy Suburban build: http://67-72chevytrucks.com/vboard/s...=574056&page=3 |
04-27-2016, 09:07 PM | #23 |
you guys are missing the important area...the firewall. You will get a LOT of noise and heat transfer from the firewall alone.
I used ice and water mat on the firewall and floor of my burb. Ive used it in numerous vehicles with good success. I heat it up and roll or press it into the floor pan areas. you don't need to do the entire panel, although i would say I probably cover 3/4 of each panel. After that I'll put down a jute backing and on top of that would be the carpet. The jute backing I do put across the entire panel if it's possible.on the roofs, I'll apply the ice barrier in sheets about 12" wide going across the roof from left to right.After that a roll of jute that is sprayed with adhesive spray. I can't say if it has fallen down-I haven't had a reason to take the headliner down to see.
you never have too many suburbans.... |
04-27-2016, 11:52 PM | #24 | |
I always use the stock insulation on the firewall. Are you saying a person needs to use the mat in addition to the stock stuff or in place of...... LockDoc
04-28-2016, 12:07 AM | #25 | |
BlahBlahBlah
Also I wasn't running carpet, just the full size rubber mats.
