04-25-2016, 08:29 PM | #1 |
1970 k2500 Axels
Hi everyone. First post here. Just purchased a 1970 K2500. I have the build sheet from the factory and am wondering if there is a way to tell what axels are on my truck.
Thanks Tony. |
04-25-2016, 09:51 PM | #2 |
Born Psycho
Re: 1970 k2500 Axels
post some pics of your diffs. should be a dana 44 front and since it's a GMC probably a dana 60 rear
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-25-2016, 09:52 PM | #3 |
All about them K’s
Front if original will be an open knuckle drum brake Dana 44 and the rear (assuming it's a gmc because you said K2500) will be a most likely a Dana 60. If it's a Chevy most likely its an eaton ho52 but could be a 60 as well. 4:11 is the standard ratio assuming it came with a 350.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
04-25-2016, 10:07 PM | #4 |
Can't post pics as the truck is at the shop getting some new inner fender fenders and a new rad support. It is a GMC. Thought there might be a code on the build sheet that would say. Thanks Tony.
04-25-2016, 10:10 PM | #5 |
Here
White K20 |
04-27-2016, 12:27 AM | #6 |
standard on my 68k20 was HO 57 and 456 gears
04-27-2016, 06:14 AM | #7 |
all these 4wds used Dana44 front axles and a K2500 would have a Dana60 rear.
04-27-2016, 08:04 AM | #8 |
Thanks for all the info. I will post pictures at some point but many of you regulars have likely seen the truck. It was on ebay a couple times. It's the green and white custom camper that at 1 time was in Washington state.
Thanks again Tony. |
