![]() Join Date: Jan 2015
Replace the existing TH350 with another TH350
Sure seems like the engine Revs are high at 65... is this normal?
1970 C20 350/TH350, LB God Bless our Troops ![]() |
Re: Replace the existing TH350 with another TH350
What is your differential gear ratio?
'72 chevy C20 Cheyenne Super |
It's Dana 60... and it's in a stock C20...
Unless it was built with an optional lower ratio your truck should have 4.10 gears.
Plugging in a nominal 30" tire diameter it looks to be 2985 rpm @ 65 mph. http://www.summitracing.com/expertad...tio-calculator All depends on what your definition of "normal" is. When new it was. To people raised on double overdriven engines it sounds like imminent destruction. Are you using your 3/4 ton truck as a truck or just a cool looking car replacement?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
SS Tim as a truck!
Ifyou are using it as a truck then you will probably need the gear it has. So then the basic question comes back to keeping the TH350 replacing it with a 200R4/700R4 or adding a gear vendors overdrive. If it is limited mileage driven keep the TH350. If you want to drive it a LOT, a well set up four speed auto can be benficial in lower rpm and higher road speeds. But it does take money and knowledge, anything less is false economy. A gear vendors would be a great choice but they can be expensive. However the usable five speed your TH350 would become is great with high drag or heavy loads like camper or trailer.
Carpe manana
![]() ![]() Join Date: Dec 2010
May be worthwhile checking the rpm with a tach to see where you stand at 65 mph. I really like driving at highway speed in my 700r4 HO52 equipped K20 but could get by with a TH350. Last night I was driving my TH400 HO72 equipped C30 at speeds up to 70 mph and it was cruising fine, didn't sound too wound up as for rpms. If you need a new tranny and don't anticipate much long distance hauling I'd keep it simple and rebuild the TH350.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
was a th350 available in c20's ? I have 373's in my truck and it screams at 70 plus mph. very usefull on the few occassions I hual something. as a daily driver it cost a plenty.
I wouls put a 400 in it or an od automatic. but remember you got a nice choice of gear ratios for that dana sixty |
Okay, I'm sticking with the TH350... thanks for all the input!
