Old 04-26-2016, 08:46 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question AC cooling with LS
I have had my LS swap for almost 2 years now and the AC has always done pretty good, well up til today anyway.
Started out just wanting to check the system to make sure it was ready for summer. Was not cooling down good like before so.... I hook my gauges up and pressures look ok.
Start the truck up and turn the ac on and before I could walk around to the front I see mist spray! High side hose on gauges has a pin hole in it! OK,OK gauges are 10-15 years old, Shut the truck off and got the quick connect undone. I may have lost a little bit. So any way I go to my buddies shop and ask to barrow his and the high side goes straight up while my buddy says cut it off.
No fans coming on at all either. Water temp is 178* by scan gauge which is what it runs pretty much at normal driving. Since the new aluminium radaitor installed last summer. The fans normally come on at 190* per the ECU.
My friend ask me why they where not coming on when the AC was on and I told him they come on from the ECU input. Which is only when the motor temp reaches 190, he said they need to be on anytime the ac is on which makes since.
So my question is, the 2 relays that run the fans are triggered by the ECU grounding them...right?
If so I want to hook them up to the clutch switch so it will ground them also whenever the AC is running.
Is this the right way to wire it?
Per this relay drawing?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-26-2016, 09:24 PM   #2
ls1nova71
ls1nova71's Avatar
Re: AC cooling with LS
That would work, but you would be better off hooking the relay up to the switch that turns the A/C clutch on rather than at the clutch itself. You want to tie it in before the high and low pressure switches otherwise when it cycles, the fan will too which you dont want. The downside to it is the fans will run anytime the A/C is on which means running down the highway they will still be on even though they wouldn't be needed then. Shouldn't really hurt anything though, just might shorten the fan life a bit.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-27-2016, 05:32 AM   #3
Andy4639
Old member
Andy4639's Avatar
I will check the tie in spot and make sure it's before the low pressure switch. Thanks ls1nova71 again you come to my rescue!
Yes I thought of this also to be true while going down the road.
I'm thinking about if I just tie one in to the AC and leave the other one alone. Do you think it would be enough to keep the condenser happy while at stop lights and idling? I did some more reading and found out 2600 CFM is min for electric fans to keep the condenser happy so both will have to be on when the AC is on.
I don't think the water temp will be a issue since they don't kick on now until around 185* according to the description.
Here is the fan kit.
PRODUCT DESCRIPTION:
Dual Fan kit, 82-02 Dual Fan Kit 12" Fans 3,100 CFM, This is a universal dual fan kit for pretty much all 82-02 f-bodies. it comes with (2) 12" fans with 225 watt heavy duty fan motors that produce 3,100 CFM, it also comes with a wiring harness, 185 degree temperature switch, and a nylon tie kit to attach it to your radiator. Mine has been hard mounted.
Deminsions:
26" wide x 15" tall
Flows 3,100 CFM
3.94" Depth
26.6 Amp Draw
Old 04-27-2016, 09:43 AM   #4
clemsonteg
I have 1 of my 2 fans wired like your first post. Mine put out 2000 CFM each, so I will see how it performs this summer and then decide if I should make changes
clemsonteg is offline   Reply With Quote
Old 04-27-2016, 10:16 AM   #5
ls1nova71
ls1nova71's Avatar
Really the only time any of this is going to come into play is when the engine is cold, which in the summer isn't very long! If your engine cooling fans come on at 185, odds are they will never go off as long as the A/C is running, so only having one fan wired on with the A/C should be good enough to keep the head pressure at a safe level until the engine warms up and the fans come on.
Old 04-27-2016, 01:41 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: AC cooling with LS
Well I wired both of them in to the clutch relay for now. They where both already tied together so it was the easy way to do it.
Fans are wired like the relay schematic off LS1 page I posted above. Sitting in the garage in park the AC will blow 45-50* AC out the vents. This is just at idle speed.
Gauge readings low side 30-35, high side is 200-225 which I was thinking is a little low still, it's about 84* outside according to my temp in the front of the truck. The prob is mounted in the front grille area a way from the heat of the motor.
Going to go drive it and see how it does on the road. I'll post back later this afternoon.
Old 04-28-2016, 03:15 PM   #7
Custom 68
Custom 68's Avatar
I just have a single fan on mine. I added a switch so I can manually turn it on when I have my ac on and am at a stop or slow traffic. Probably not the best way because my switch has 3 positions, one is on when switched, the middle is completely off and the last is computer controlled. I don't feel the need to run it when going down the highway at speed when the engine is cool and the AC is on, maybe that is wrong and I would always benefit from it. When at shows or the power tour or just lots of traffic I can turn mine on in anticipation of it getting hot to get a head of it so to speak. I may change things around but right now it works for me. It is usually on the "automatic" side.
I don't know if the computer can compensate for speed and AC on I have not dug into that. I do know that when the AC is on it sends a signal to the computer this bumps up my idle some but don't know that it does much else.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-29-2016, 09:42 PM   #8
Andy4639
Old member
Andy4639's Avatar
I have been looking all day on the net about electric fans and how to run them with the AC on and not one article talks about it except the Dakota and Painless mod that is $270.00!
The Dakota one want let it turn back off once it's turned on though.
Nobody has come up with anything that I can find.
Old 04-30-2016, 01:16 PM   #9
ls1nova71
ls1nova71's Avatar
You could always use a trinary switch, but that would require breaking the system open to mount in a line. Using a trinary switch would only allow the fans come on when head pressure is high enough to need the fan, running down the highway the pressure would be low enough that the fans wouldn't be needed and therefore the fans would shut off.
Also, make sure you're pulling as much air through the condenser and not around it by blocking off any open spaces between the condenser and core support/radiator. This is what I did to mine.
Old 04-30-2016, 02:53 PM   #10
clemsonteg
Since my system isn't charged yet, I'm going to swap my binary switch for a trinary switch. I also plan to wire the fans so they run together with the AC, but they will still run independently using the temps in the PCM. This is what I'm thinking at the moment, all of the triggers are grounds so I'll use a diode to keep the low temp PCM ground from activating the high temp fan
Old 04-30-2016, 05:13 PM   #11
Andy4639
Old member
Andy4639's Avatar
I looked at the trinary switch yesterday but as stated don't want to open up the system unless I have to.
What I did today also before the cruise stuff showed up. I took the relay's back a part and now have one fan only running with the AC on at all times.
Both fans will still come on with the PCM if the AC is not on.
Riding over to the little cruise in this morning it was 75* out and the temp never got over 178* in the motor the fans never came on. No AC.
Driving home it was 82* and I ran the AC the whole way home the motor temp never got past 178* except when I pulled into the garage and let it sit running for a few minutes with the AC off before I turned it off. They kicked on at 188*according to my scan gauge 2 reader right before I cut it off.
Thinking about maybe putting a hotter thermostat in it to get it up to a better operating temp.
Old 05-16-2016, 08:57 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: AC cooling with LS
Ok guy's I have been searching for a answer to my fans running all the time when I'm on the road at speed. We all know that these fans are expensive and burning up $300.00 fans isn't going to be fun no matter when they go out, so I finally think I have it figured out. I ran out of time so I'm going to test drive it tomorrow after work and see.
I even came up with a little light to tell me if it's working are not. I don't know if I'll keep it in the truck are not we will see. Really depends on how bright it is when it's on.
Ok here is what I did:
I wired a micro switch into the AC on wire to the relay I added a few weeks ago. Like in the picture with the arm extended with a flap on it to catch the air and turn off the fans once it see's enough air flow. I have it mounted inside the grill. Hopefully it has enough wind when driving it to shut off. I bolted it in place and put my fan in the front of the truck and it shut off so I hope it works.
I wired the small light on the back side of the switch so when the fans are on the light is to this way I know when they kick off at what speed.
When I know it works I'll post pictures of mine. They still come on at temp also.
Old 05-17-2016, 05:57 PM   #13
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
My PCM requests the low speed fan with the AC clutch. I have a separate factory pusher fan wired to the AC clutch. Both cycle. I am using the 2 speed mark 8 fan and stock thermostat so mine is 200+in traffic, but that's no sweat for the 5.3 and the high speed rarely comes on, has to be really heavy traffic and 95+ outside. Do you have the AC input wired in? mine goes to c2 pin 17 (99-02 truck) Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-17-2016, 07:34 PM   #14
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: AC cooling with LS
Mine is done. The paddle switch will turn them off @20-25 MPH and then back on. I just test drove it. I even installed a small light on the dash to LMK when they are ON/OFF!
I still have the temp controll also by the PCM @185* on! I have never seen the temp over 197*.
