Old 04-28-2016, 09:44 PM   #1
McLovin
McLovin's Avatar
1991 Crew Cab Dually 2wd (New to Me)
Just picked up a local 1991 Crew Cab Dually 2wd Camper Special. 454 with the 4L80-E. 80k original miles. Its an SLE Sierra. Power Windows, locks, AC and Cruise. So far I am really loving the overdrive transmission and TBI.
Picking up a travel trailer tomorrow. Can't wait to see how she pulls.
It needs an exhaust manifold gasket as it has an exhaust leak and a couple new power steering hoses. Otherwise it just needs a good cleaning and away we go!
Would like to eventually lower it slightly with some bigger wheels.
McLovin is offline   Reply With Quote
Old 04-28-2016, 09:46 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: 1991 Crew Cab Dually 2wd (New to Me)
nice!!!!!
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-28-2016, 10:37 PM   #3
flashed
Wow ,that is a nice one .
flashed is offline   Reply With Quote
Old 04-28-2016, 10:40 PM   #4
Valarius_Starchaser
Valarius_Starchaser's Avatar
Oh so nice!!! First year for the 80e if I recall
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 04-28-2016, 11:20 PM   #5
McLovin
McLovin's Avatar
Yes, I believe it is too. So nice to have that overdrive in a 3500 crew.
Old 04-29-2016, 07:51 AM   #6
Desert1957
Desert1957's Avatar
You will enjoy it, I really love mine. Great truck , does everything I need and more.
Desert
Desert1957 is offline   Reply With Quote
Old 04-29-2016, 12:15 PM   #7
1968vetL-71
Junior Member
1968vetL-71's Avatar
Nice score!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 04-29-2016, 04:40 PM   #8
Woodyboat
Woodyboat's Avatar
How do the doors open and shut? By that, I mean do they fall down or out of alignment? Do they close easily or do you either have to pick them up to close them or do you have to slam the dickens out of them?
Woodyboat is offline   Reply With Quote
Old 04-30-2016, 06:32 PM   #9
Woodyboat
Woodyboat's Avatar
Now THAT is a good looking rig. The ole chevy didn't have too much problem keeping up with traffic, did it?
Old 04-30-2016, 06:34 PM   #10
McLovin
McLovin's Avatar
No, no trouble at all. I took it easy and drove around 55-60 the whole way home making sure it was out of overdrive. Truck ran great and the trailer didn't sway or do anything silly the entire way. I need to raise the weight distribution hitch slightly as the rear of the trailer is up a little higher than I would like. Also need to adjust my trailer brakes.
Old 04-30-2016, 07:47 PM   #11
Woodyboat
Woodyboat's Avatar
So what kind of brake controller are you using? ... and does the trailer have brakes on BOTH axles or just the one?
I ran a landscape business in Nashville for twenty years towing trailers every day. I went through a lot of different controllers before I found some that worked really well. The one that has always made me the happiest is the Tekonsha Prodigy P2. I LOVE that unit! But of course, this was always after we got the drums on each axle dialed in correctly. I rarely was ever able to buy a landscape trailer that had brakes on both axles. And to my way of thinking, one axle just wasn't enough. So I would always buy a conversion kit to change the idler axle to a brake axle. I often found that a trailer would have the brake axle installed backwards too. The trailer manufacturers must have been hiring guys from "America's Most Wanted." Finally, I bought all the metal fab tools and my guys and I started building our own trailers. That way we knew just what we were getting and we got them just the way we needed them.
A lot of people feel like a big old one-ton truck can haul down some really large trailers and it can right up until you hit some gravel or it starts raining. Then you'll find out very quickly that you need brakes on every wheel that touches the ground.
In spite of having a couple of one-ton trucks in my fleet, I still liked having the weight distributing hitches too. They just made for much safer, more controlled and more comfortable towing. IMHO, it's the best thing next to a fifth-wheel or goose-neck trailer.
Old 04-30-2016, 10:13 PM   #12
McLovin
McLovin's Avatar
I had the dealer install a Tekonsha Voyager. Its one step down from the P2 in that it doesn't have the digital display. Before I left the dealer I should have calibrated it and I didn't so the trailer brakes bite hard on initial pedal push. I need to dial it back a little bit as it made it really jerky on the way home. With a 7k dry weight I wasn't leaving the dealer without trailer brakes. The trailer max capacity is near 9500lbs.
